Forklift Snow Plow
  • Forklift Snow Plow
    I made this for work. Got it finished in my spare time and now there isn't anymore snow. Let me know what you think. Pics aren't greatest but you'll get the idea.
    Thanks, Goon
    Snow Plow :
    Thanks, Goon
    Cargoon, Hi; Looks Good, First what is holding it on to the Forks ??
    Second how did you make the Blade ??
    Where are you Located? Just Curious??
    ............ Norm :
      nice plow but I dont think a forklift would get enough traction to plow snow
      This is an automotive discussion forum that has some great infromation
      www.autobodytoolmart.com/shoptalk
        Most forklifts I've been around would have gotten stuck on an ice cream cone. YMMV. It may be awsum....time will tell.
        Run it over to Seattle and try 'er out
        On the other hand if it doesn't work as expected you can drop it off at my shop and leave it
        Miller 30-A Spoolgun
        Miller WC-115-A
        Miller Spectrum 300
          if it were used on a skid loader it would probly work beter but in that case it would probly be better to just put a quick atach plate on to mount it directly.
            Put about a ton behind the plow on the forks........Then I bet it will push snow.
            My forklifts get stuck on the least bit of snow without a load.
            RoyB
            Dartmouth, MA
            http://www.rvbprecision.com
            Millermatic 185 MIG
            Miller Diversion 165
            Purox W200 O/A
            Grizzly 9957 Mill
            Grizzly 4030 Metal Band Saw
            Grizzly 1050 Knife Belt Sander
            Jet 1236 Metal Lathe
            TP Blast Cabinet
              If he puts some weight on the forks he might be ok as long as it's not too icy.
              Norm the forks go into what looks like a rectangular tube, then if you notice the two bolts in those tubes will go through a hole in the end of the fork. The forks likely bottom out against the blade but you need the bolts so the blade doesn't pull off when you back up and forget to raise it.
              at home:
              2008 Suitcase 12RC
              Spoolmatic 30A
              WC-24
              2009 Dynasty 200DX
              2000 XMT 304
              Sold:MM130XP
              Sold:MM 251
              Sold:CST 280
              at work:
              Invision 350MP
              Dynasty 350
              Millermatic 350P
                Thanks, Goon
                Nice job, but I have two comments..... one, it looks like your blade is tipped a bit too far forward... and two, there's no blade or edge trip.... somebody's gonna get hurt... seriously.
                Bobcat 225NT
                Cutmaster 52
                Lincoln Weld-Pak 100 buzz box
                Caterpillar TH63
                '07 Kawasaki ZZR600
                  Thanks
                  Thanks for all the comments. I have attatched some better pics withe some mods to it.
                  In responce to:
                  nfinch86 - 1. I have welded chain to the sleeves
                  2. The blade was an old damaged reservoir from a locomotive
                  3. Britich Columbia Canada (Best place on earth, especially if you like to pay taxes)
                  Metalmltr - The plow is at the end of the forks so I can pick up a pallet with some brake shoe's or something on it for wieght.
                  CWagner- The bolts do not go through the forks. The other two holes in the sleeve are to turn the blade, if you want to puch the snow to the left you put a pin in the hole on the right and the fork on that side can only go that far. Blade turns.
                  Bretsk2500 - I put in bigger bolts so it doesn't lead forward to far anymore. I only had a 1 1/8" drill that was sharp enough to do all the holes. I will add a blade or edge strip, don't want any injuries.
                  Thanks for all the comments guys.
                    I wish I had pictures of our first forklift. It came with a bucket, a blade, two sets of forks. She was a real cream puff! The blade had a steel box built behind it on the forks with 1000# of weight in it. It would push snow, gravel (if you took small bites) and do a good job. Of course it was new in the early 1960's and only lifted 4000#. Your blade looks to me to be a bit far away from the fork mast. This will make it very sensitive to tipping the mast. Can be a bit of a surprise hitting a frozen lump with the mast tipped back too much!
                    Good looking blade all the same.
                      Looks one heck of a lot better than anything I've ever seen with a wooden handle on it!!! I'll bet it does what it's intended to do.
                        You can buy, or make, tire chains for fork lift tires.
                        JTMcC.
                          looks pretty good. hope it works out ok for you
                          Dylan
                          RED BIRD WELDING
                          "Experience is simply the name we give our mistakes"
                          HH-140
                          Crappy stick welder
                          Victor supper range II
                          Makita grinder
                          more stuff i don't feel like listing.
                            A few co's make them. There's one with a cool video - works great! ChinookForkPlow.com - yours is built like a tank though!
                              If this was mine I would add a bolt on cutting edge to the bottom. Other than that I like this.
                              Millermatic 185 + Shopping cart .. cart
                              Metabo 4 1/2" grinders.
                              Milwaukee v18 cordless drills and jobsite radio!
