OT question on metal forming
  • OT question on metal forming
    I have an old chaise lounge piece of outside patio furniture. It is made of round formed aluminum tubing and has plastic strap webbing attatched for the body to rest against. My question: The aluminum is 7/8" OD and .070" wall, .740" ID. OK...
    The 90 degree bends seem to be mandrel bent from the reduced diameter at the bend but to my surprise........inside the aluminum tube(not all) is a steel 1/2 " x
    .050" tube inside which is a very sloppy fit. What is this about? Would it be to help the aluminum to not collapse but like I said it's looks mandrel bent. I am tearing it apart because I need the tube for my heli project. We don't use it and it's been in my junk pile for years. No.........I don't use present deck furniture for my projects.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    To keep the corners from unbending and wracking?
    Just a guess. I have no real knowledge....
    Frank
      Is there a joint there?
      I see this in boat bimini tops where the alum. sections join. I always assumed it was for the purchase of the screws holding the sections together.
        I was asked to fix some of the chairs, not yours. LOL
        Had the steel in it as well, only thing I could figure was for strength.
        Be safe
        Jeff
        Give more than you get and
        you will get more than ya need.
        This is true for the good and bad
        that life puts out.
          If the diameter was reduced then it would look as if it was NOT mandrel bent.
          Mandrel bending is used to keep the diameter consistent.
          The steel was more than likely used as a cheap way to keep the material from kinking while bending on their bender.
          I would think twice about using unknown imported used material on even the most unimportant projects... unless it was to repair/beef-up other lawn chairs which are nortoriously known for being junk.
          Miller 30-A Spoolgun
          Miller WC-115-A
          Miller Spectrum 300
            FK is correct the reduced section diameter is indication of non mandrel forming.
            If the material is in good condition free from corrosion use it.
              The reduced diameter is only on the inside of the bend. There are no wrinkles
              on the inside of the 90 degree bend. The outside of the bend is smooth with the tube. I would think the tube would have ovaled if not in a mandrel. It's not. The wierd thing is, as many 90 degree bends as it has, the steel round metal was only in one piece. It fits so sloppy I can't see how it would help much. Another wierd thing is that some of the aluminum tubing has what looks like a welded seam inside like some steel but then again, some is totally smooth inside. The wall of the aluminum is .065 and I wouldn't think it would
              kink if bent properly. ....maybe the foreman was walking by and saw the steel tube on the floor and told the worker to clean up his area so he shoved it inside the aluminum tube.
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
                Originally posted by monte55 View Post
                I have an old chaise lounge piece of Wally World cr@p outside patio furniture that we bought 20 years ago. It is made of round formed aluminum tubing that is oxidized 1/2 way through and has plastic strap webbing attatched for the body to rest against (although the webbing is pretty much desinegrated through the years....)
                You're using THAT on your helicopter project??!!!!
                Well Monte, it's been AWSOME knowing you... I'll think of something to put on your headstone....
                I'm not late...
                I'm just on Hawaiian Time
                  What!!............you've never heard of a chaise lounge on a heli? Hey...I'm laying back and gettin down with my bad self. You have a problem widdat?
                  Uh huh..oh yeah..ain't it funky now.
                  Nick
                  Miller 252 Mig
                  Miller Cricket XL
                  Millermatic 150 Mig
                  2-O/A outfits
                  Jet Lathe and Mill
                  Propane Forge
                    Hey Bert...........I just got my $900 upgrade 3D program(don't know how'll I pay for it).....send me a pic or whatever of your metalworks Logo and I'll see what I can come up with.......Nick
                    Nick
                    Miller 252 Mig
                    Miller Cricket XL
                    Millermatic 150 Mig
                    2-O/A outfits
                    Jet Lathe and Mill
                    Propane Forge
                      Bert......as far as something to put on my headstone..........cash is always
                      nice
                      Nick
                      Miller 252 Mig
                      Miller Cricket XL
                      Millermatic 150 Mig
                      2-O/A outfits
                      Jet Lathe and Mill
                      Propane Forge
                        lol !!!!!!!!!!!! For KEEPING it as a chair, cool, I thought you were going to use
                        PARTS out of it and use it for the actual heli itself!!!
                        you gonna have a little margarita holder in their too???
                        I'm not late...
                          Actually some of the tubing will be used on the heli. Not as a chair. The material is in very good shape. It will be part of a handle. No corrision at all. It was power coated. I just was tigging on it and it went fine..........Nick..so there!
                          Nick
                          Miller 252 Mig
                          Miller Cricket XL
                          Millermatic 150 Mig
                          2-O/A outfits
                          Jet Lathe and Mill
                          Propane Forge
                            Like I said I just tigged a t joint with the round tubing and beat the heii out of it with a hammer and it hung in there. No breaks etc but the tube was squashed to bits. Yaaaaaaaaaaaaaaaa
                            Nick
                            Miller 252 Mig
                            Miller Cricket XL
                            Millermatic 150 Mig
                            2-O/A outfits
                            Jet Lathe and Mill
                            Propane Forge
                              Powdercoat from China
                              Well, testing you're doing is cool....just don't wanna lose you
                              I'm not late...
