My Welding Truck
  • vin-man welding
    OK. thats a great idea. i don't think I'd try it with my Chevy 1 ton with fiberglass sides. did you reinforce the bed?
    the company i worked for had a 350 with a rack and we'd carry some heavy beams on it till one day we show that the bed was pushed down about 1.5 inch's and the side were pushing outward. the rack never bent but the body was bad off. we put a cross brace and kept on running it.
    i really like it, I'm going look at my bed to see if i can do something.
  • JSSEC
    Reels
    Will post tomorrow afternoon.
  • admweld
    Nice another ford man.Cool setup pretty slick.
  • J. Strunck
    Welding Truck
    Plenty Slick!
    John
  • Portable Welder
    I own a couple rigs of my own, I know how important it is to have the ability to carry 4 x 8 sheets of wood.
    I think putting your welders up high is a good idea if you want to work out of a pick up bed.
  • JSSEC
    Drinks
    Water and Diet Coke on those hot 12-16 hour days.
  • fendermender
    That is a very badass rig!
    What is in the blue cooler?
  • lanceman73
    Nice!!!
    It's nice having both! One for welding and one for a truck. I built my truck that way. I have a 4' x 8' bed with it loaded, check it out. Also, I built the monster from scratch. The post is "Build your own service truck"
  • JSSEC
    That was my intent
    Like I said above It was a lot more useful for me to leave the factory bed and raise my welders. I have had numerous welding truck with flat beds like most welders but my bed was covered with my welding gear and never could carry any additional equipment or supplies. I can still carry a 4' x 8' sheet, ladder or 5 gallon buckets of primer paint. I don't know for sure but I think the factory bed is even lighter, as show in the photos I scale 11000 lbs with the tool boxes full and 21900 towing the fork lift in the first photo.
  • Goulet!
    Thats a nice set up. I like that. You get alot more out of the truck that way.
  • J. Strunck
    Service Truck
    Nice pics of your service truck!
    Take Care,
    John
  • Railmen
    Originally posted by JSSEC View Post
    I fabricate and install stair and railing for www.urbanactive.com gyms. Use this rig when installing stair and railing first welder is tacking it in place with a 7018 stick rod and running power for grinder, band saw, hilti drill etc and the second welders is sewing it up with .035 feeder mig gun. If you run accessories from the rear welder with the mig you notice it a lot.
    IC just a thought, I am always looking for ways to cut costs and make things smiple.
    But if it works then DO IT, as my old boss says..............
    other then that looks good.
    Railmen
  • JSSEC
    Originally posted by stick man View Post
    Ive seen your rig around town several times always commented to my help how good it looks, hope your busiser than we are.
    Works great for me
  • JSSEC
    Bobcat Usage
    Originally posted by Railmen View Post
    well now i caught on i see you have two welders on that rig...............
    why the need for two??
    you could save yourself lots of space and fuel cost by maybe running like a CST280/250 off the front of your newer 250, i guess it just depends on how much power you need on the second arc?? or even like a maxstar 200 draw very little and work great.......
    just my two cents.
    i have a TB302 and i have run a XMT 304 off the front and run both machines on 5/32 rod all day once....
    Railmen
  • JSSEC
    Bolts Down
    Originally posted by MMW View Post
    Looks nice! I can't tell from the pics what holds everything in place. Do you pin it after you set it on? One thing I don't like is the acetylene laying down, yes I know it is tilted but it should be upright.
    2"x2"x1/4" tube running the length of the truck on each side welder frames bolt to 3/8" bolts x 4 for each welder 80K miles no problem. As for the tank I have heard that they will explode for 40 years but have not had any problems. Can tell you how many jobs I pull up on and there is a guy in the gravel cutting re-bar with tanks laying flat on the ground. With the Spectrum 375 Plasma on board very seldom use it torch.
