need to weld jonny joints onto bars
  • need to weld jonny joints onto bars
    i need to weld some jonny joints onto some 1.5" .250 wall tubing i have a dynasty200dx as be the weld calc i dont have enough welder to do it i would see this as a fillet weld the jonny joint shell is 3/16" the calc is sayin around 260amps and 3/32 orange tungsten what do yall think do i need more machine? i have a mm251 but feel better tiggin theese. both pieces are mild steel dom tubing.
    DYNASTY 200DX
    SPECTRUM 625
    MM 251
    BWE
    260 amps is Way too much for a 3/32" tungsten. You should only need about 150 amps, max! You can bevel the tubing and do mulitiple passes to fill it but you probably only need one pass. You could also do a wash pass and add filler at both sides of the "wash" movement. Just grind any mill scale off the johnny joint first.
    my two cents...
      oh i screwed up i meant 1/8 orange tung!!
      ok so educate me on the wash pass? since my machine is only a 200a machine i dont think i can make the weld but i know the inverter machines will run lower amps.
      thanks again for all the help!!
      DYNASTY 200DX
      SPECTRUM 625
      MM 251
      BWE
        That 200DX will easily weld that!
        I welded this yesterday,
        2"x3"x 3/16"wall square tube welded to 3" x 1/2"wall round with my 200DX - 3/32 tung at 160 amps - more than enough!
          TS-OFF-ROAD,
          that is INSANE!!!
          I'm hoping to get my contractor's kit soon for my new Dynasty 200DX (air cooled torch). I want to weld 1/4" thick aluminum square tubing for a truck rack. someone told me I'd probably use about 175 amps to do it. I'm guessing that would put me in the 20% duty cycle range. Can you tell me what type tungsten/size and other info you would try?
          thanks,
          bert
          I'm not late...
          I'm just on Hawaiian Time
            TS,
            re: pic, what is that for? I was thinking trailer axle
            I'm not late...
              ts- that looks awesome.
              they look like some suspension link bars if ya ask me about the same thing im doing but using some differnt material. im 4 linkin my F350 front and back bar air bags the back is done just gotta do the front now. 2" lift along with the air ride. ill never have a truck on leaf springs again.
              DYNASTY 200DX
              SPECTRUM 625
              MM 251
              BWE
                Whats a jonny joint
                www.wmauto.com
                www.walshoriginals.com
                www.seabeastart.com
                http://members.fotki.com/Bart1971/about/
                  Originally posted by Bart View Post
                  Whats a jonny joint
                  http://currieenterprises.com/CEStore/johnnyjoints.aspx
                  Nice work TS! Looks like only one pass too...
                    Ts-offroad , pruddy Weld
                    Inferno Forge
                    Chris
                      That's going to be a spare tire mount for a FJ40. The hinge is what is pictured.
                      Bert, for the Aluminum you want to weld, it really depends on the mass of piece as to the amps you'll need. I usually save the big stuff for my spool gun, but I have welded some smaller 1/4" and 1/2" plate with my 200DX. I used 3/32" ceriated(orange) sharpened to a pencil point, 180amps, 120Hz AC, 75%balance, and 15cfh gas.
                      Thanks for the comments everyone.
                      By the way, this is a Johnny joint. http://currieenterprises.com/CEStore/johnnyjoints.aspx
                        TS, thank you very much for the info. Your pic looks like it's stainless, and a robot did it!! for that 1/2" thick walled, you only used 160amps????
                        or did I miss something?
                        thanks again,
                        bert
                        I'm not late...
                          Thanks,
                          160 amps was plenty. That 1/2" tube is only about 5" long, so it heated up quick.
                            awsome job....
                            I'm not late...
