Hardening Metal
  • Hardening Metal
    Does anyone have a good easy method to harden chisels, center punches, etc using a O/A torch and some cooling method ? I once heard about using certain oils.
    Ken
    What else is there besides welding and riding. Besides that
    Miller Thunderbolt XL 300/200 AC/DC
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    harding
    Me dad said that all there is to do is get it hot and it cool it in brunt motor oil. He said that is what they did at the shop for Delta. Right or not that is what have done to.
      metal harding
      just google how to harden metal. and that reply was very well typed.
      TB 325
      TB 302
      dynasty 200sd
      spoolmatic 30a/wc24
      suitcase x-treme 12vs
      miller 211
      evolution rage 2
        One more step- Temper.
        Basic breakdown-
        Heat & Quench ( water, Motor erl or Veggie erl-- whatever you want to use)
        Tool is now Hard but Brittle- Breaks easily
        Polish/Sand the Tool- this helps in seeing the tempering Colors
        Heat again until tool turns the Color you need for whatever application- Quench- This part is tricky as the temper color happens FAST.
        Now the Tool is just right- not to hard and not too soft.
        As Vin-Man said- Google has tons of Info.
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          Originally posted by Iron Head
          Here is the method I use for carbon steel, first preheat the area too 1100ºf (dull red) and let free air cool slowly. This removes any stress in the material.
          Next reheat the same areas to a dull red then quench in oil until cool. Used motor oil works well as it adds a small amount of acids at the same time. This method also surface hardens the steel.
          Reheat the steel area again too 500º then quench in oil until cool. This quench adds temper to the steel.
          Thanks, great answer. I've got some old chisels and punches that need restored.
            Thanks Iron Head, Im going to give that a try.
            Ken
            Hobart Handler 187
            Dewalt Chop Saw
            4" Air Grinder
            Die Grinder
            Rigid Drill Press
            2009 FXDC
              okay, so I'm responding to an older post. Just joined and am a new Miller owner.
              Anyhow, my back ground is in the Blacksmithing trade. No, not horses. But working metals by hand with forge and anvil and hammer. I've made hundreds of punches, hammers, chisels, etc.
              Heat treating metals. any metals for that matter can be a difficult proposition.
              If you buy the material outright you get a spec sheet that will tell you what temp, what fluid or air, and what kind of performance you can expect with what temper.
              So, for the most part if these are bought chisels, punches, etc. they are more than likely O1 or A1 or D2.
              The first is oil hardening and you can use just about any oil but auto transmission oil has built in cleaners that will help to remove the burnt oil film.
              A1 is air hardening and you just bring it up to the right temp and let it cool in a stream of air than polish and temper.
              D2 can be W, O hardened depending on cross section.
              Hope this help.
                But if you took a chisel out of the drawer with no labels what method would you use?
                  Heat Treatment
                  I have to agree with the previous posts in regards to the addition of transmission fluid to motor oil for hardening. In my personal experience, straight motor oil can and probably will ignite due to the flash point of oil. I am not a chemist however the addition of transmission fluid did not allow the motor oil to ignite when I was hardening the next item.
                  Hope this info helps.
                    kbar....
                    By using oil Harding tool steel is your best option. This is also know as drill rod or 0-1, quench with salt water or oil (old motor oil is fine) then polish and draw some of the brittleness out of it, usually to a light straw yellowish color.
                    But if you need to harden mild steel your only option is a case hardening. The Physical properties of mild steel do not posses enough carbon to make it hard all the way through. By using a case Harding process called cyaniding or carbonitriding. There are others but these are more garage shop practical. You can use this application to achieve what you’re looking to do. It is basically heating the material to a given temperature and soaking it in a carbon bath then you will need to polish the material and heat it slightly to draw some of the brittleness out of it, usually to a light straw yellowish color.
                    I would suggest practicing on a few sample parts before tackling the actual part.
                    Good luck!
                      hardening steel
                      Kbar,I have tried a few different techniques for hardening steel for center punches. The absolute best tip I have is from a member of an international farrier group. Use a steel that has medium to high carbon content. I found an air chipper blade works best. Grind the basic shape you want. Fill a bucket of water to quench hot steel. Using a torch, slowly heat the end of the punch, frequently check to see that the steel will pull the magnet,(the trick is to heat the steel to the point just before it loses its ability to draw the magnetic field). If it gets so hot that the steel will NOT pull the magnet then the process will need to be started from the beginning. Let the steel cool off and start again.The process is described as heating the iron molecules to the point that the carbon molecule is trapped in the center of the cluster of iron molecules. So at the point just before all of the magnetism is lost quickly quench the tool in water to catch the carbon at the hardest point. Now you have hardened steel! Enjoy!...................Barry
                      Big Blue 300
                      Miller 175
                      Cutmaster 75
                      Dewalt chopsaw
                      Makita chopsaw
                      '89 Dodge W/ custom flatbed
                      Grinders
                      Wildcat 7"
                      Makita 5"
                      Milwaukee 4 1/2"
                      Dewalt 4 1/2"
                        Chevron makes a quenching oil with a high flash and fire point. Part number 233641 quenching oil 70.
                        Glenn
                          Believe me....tranny fluid will flash in the right situation....a buddy of mine got blown several feet into a wall by the stuff.
                          Miller 30-A Spoolgun
                          Miller WC-115-A
                          Miller Spectrum 300
