Anyon know of a slick way to get a BUNCH (like 10 coffee cans full) of nuts, bolts, studs, and washers clean with minimal labor?
Nuts and Bolts
a plastic bead blaster would do the trick.
we have one at work and it cleans rust and dirt off in no time, if you could find someone that had a blaster you could use
you would need to put a handful in a cup that had lots of holes in it. this would let the plastic media blast threw the cup with the nuts and bolts in it & as you blasted you would shake and turn the parts so that everythings gets blasted. blow off the excess dust and blast another cup full till you had them all clean
hope this helps , this is the fastest way I know of
.............. Richard
What is it that needs to be cleaned off; grease,rust,etc?2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
Originally posted by Flyingpig View PostBuy new ones?I usually do buy new ones - thats why I have 10 can full of used ones - guess I'm too cheap to throw some stuff away
Most of the ones I want to clean are either rusty or caked with grease. there are some engine bolts, although I usually throw away stock stuff and replace with ARP bolts - those get cleaned by hand. Some of the engine bolts I keep for a cheap claimer motor. There are a bunch of body bolts for fenders and such that I would like to clean that are rusty and have paint on them.
Originally posted by Paul Seaman View Posta parts tumbler is really slick with a small amount of dish detergent and water it shakes it rubs off the grit until the parts are clean. The one I I have seen looked like a minature concrete mixer and it shook like an ultrasonic scrubber.
Very cool by the way.
Good Thread
Use this machine with this abrasive media in it.
It works wonders on screws and bolts. Smoothly cleans oxidized metal. Only problems are that it doesn't really clean the internal threads and it won't clean grease. If they have dried grease, wash them in kerosene first.
Really cleans external threads good.
I suppose if you were really brave, you could use this media along with quart of kerosene, but that sounds like begging for a fire.
Originally posted by Bodybagger View PostUse this machine with this abrasive media in it.
get a 5 gallon bucket of hydrochloric acid to dunk them in. the acid will dissolve any non-metal it touches so be careful of getting it on yourself, but overnight in that stuff will eat away paint, grease, grime, soft chrome, silicone, all kinds of plastics and even wood if its attached. for small parts i have a small bucket with holes in the bottom to hold them and big parts i just dangle in attached to baling wire. just make sure you rinse with water thoroughly after you pull them out to neutralize the acid, and be careful not to get any on anything non metal you want to keep...including yourself
Originally posted by CWB View Postget a 5 gallon bucket of hydrochloric acid to dunk them in. the acid will dissolve any non-metal it touches so be careful of getting it on yourself, but overnight in that stuff will eat away paint, grease, grime, soft chrome, silicone, all kinds of plastics and even wood if its attached. for small parts i have a small bucket with holes in the bottom to hold them and big parts i just dangle in attached to baling wire. just make sure you rinse with water thoroughly after you pull them out to neutralize the acid, and be careful not to get any on anything non metal you want to keep...including yourself
