Strange noise in Syncrowave 200
    Phila and Ace,
    thanks
    I'm not late...
    I'm just on Hawaiian Time
      I have a Syncro 200 and every sound it makes is new to me.......never have tigged before. But..........when I lay down a good bead........all those sounds
      become wonderful.........THANKS Miller for the sounds. Some new guys ask on what their speed should be........not being an expert, I can relate it to running a caulking bead............don't move untill the desired amount of material is deposited. If you can move while applying in a smooth fluid movement,.....great. Just pulling a trigger does not make magic..........control makes magic. Look a KB FAB's and others welds and I'm sure they don't close
      their eyes, pull the trigger and hollar sh1tt, and hope the weld comes out OK.
      Sorry to have rattled on..............Nick
      PS not really!
      Nick
      Miller 252 Mig
      Miller Cricket XL
      Millermatic 150 Mig
      Miller Syncrowave 200 Tig
      2-O/A outfits
      Jet Lathe and Mill
      Jet 7x12 horz/vert band saw
      DeWalt Multi Cutter metal saw
      Century 50 Amp Plasma Cutter
      Propane Forge
      60" X 60" router/plasma table
        the hissing that you hear is the spark gap on the other side of the machine.
        this is normal. its not a gas leak. I thought the same too until i did some exploring. Uncanny how an arc can sound like a gas leak....
        Miller 251/30A spool
        Syncro200
        Spectrum 625
        O/A
        Precix 5x10 CNC Router12"Z
        Standard modern lathe
        horizontal 7x12 bandsaw
        Roland XC540 PRO III
        54" laminator
        little dog
          Originally posted by ttype View Post
          The weld puddle pops & bubbles during the weld, so post flow shouldnt be the problem
          Hey ttype,
          I know this thread was started a very long time ago, but have you ever found your problem? I have the exact same thing that just happened to me... very frustrating... Thanks, hope this message finds you
