Recent structural work pics
  • Recent structural work pics
    A few pics some of my latest work.12"x4"x3/8"HSS 16'-8"long gussted with 6"x4"x1/2" HSS 9' long with a 8"x4"x1/2" angle clip on the bottom.All galvanized as its to extend a existing car wash bay.The other a W-10 49lbs./ft I beam 18'-9" long on top of 2-12"x6"x3/8"HSS vertical columns.And me on the ladder fluxcore welding.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    What kind of flux core wire are you running?
    Kelly
    Trailblazer 301D
    2 XMT 304's
    Dynasty 300 Tigrunner
    Spectrum 2050
    XR with ALUMA-PRO
    12RC suitcase
    Millermatic 251
    60a feeder
    Ellis 1600
    Bridgeport
    16" southbend
    Too many Hand tools...
      NR-212 OR 232 .068 OR 5/64 dia.Started yesterday with .068 finished with 5/64 used 212 on this job all i had on the truck at the time.
      BB402D
      TB300D
      DIMENSION652
      MM250X
      MAXSTAR140
        This may sound silly, but have you ever had an inspector tell you you couldn't use wire feeders? I ran into that on a job, the customer called for us to use straight up flux core(no dual sheild) and when we got there the D.O.T. inspector said no way...
        Kelly
        Trailblazer 301D
        2 XMT 304's
        Spectrum 2050
        XR with ALUMA-PRO
        12RC suitcase
        Millermatic 251
        60a feeder
        Ellis 1600
        Bridgeport
        16" southbend
          Yes on bridge code work,cover plates mostly,they want you maintain interpass temps.They usually give you a WPS before you start the job telling what process they want.
          BB402D
          TB300D
          DIMENSION652
          MM250X
          MAXSTAR140
            The customer did...( it's a well known bridge contractor ) they had all the paperwork there, we had all our certs, it was a railroad bridge, oh well... we got it done anyway, i digress...
            Kelly
            Trailblazer 301D
            2 XMT 304's
            Spectrum 2050
            XR with ALUMA-PRO
            12RC suitcase
            Millermatic 251
            60a feeder
            Ellis 1600
            Bridgeport
            16" southbend
              Just a quik photo of a some beams we put up for a limo company
              Kelly
              Trailblazer 301D
              2 XMT 304's
              Spectrum 2050
              XR with ALUMA-PRO
              12RC suitcase
              Millermatic 251
              60a feeder
              Ellis 1600
              Bridgeport
              16" southbend
                What did they use them for?And what are the sitting on? looks like some 1/2" angle clips with gussets.
                BB402D
                TB300D
                DIMENSION652
                MM250X
                MAXSTAR140
                  3/4" clips w/gussets, they needed more room to turn the limo's into the bldg. so we cut out a coll. and added these beams like headers, the engineer wanted us to hang them by not more than a 3/8" wide x 18" long bead... i asked if i could set them on clips, mainly because i had to set them up there with a machine, and they each weighed in at 3700#, i felt better with a shelf to rest them on... call me silly
                  Kelly
                  Trailblazer 301D
                  2 XMT 304's
                  Spectrum 2050
                  XR with ALUMA-PRO
                  12RC suitcase
                  Millermatic 251
                  60a feeder
                  Ellis 1600
                  Bridgeport
                  16" southbend
                    Column
                    I am not trying to be critical, but dont you think the columns you used are a little out of proportion to the size of the beams?
                      Not my call.General contractor/Carpenter had drawings from structural engineer/architects hired by building owner.I just weld and install steel for a living.I don,t size it up.If it was say a plowframe for a big hiway sized plow truck then thats a different story i build what i know works.
                      BB402D
                      TB300D
                      DIMENSION652
                      MM250X
                      MAXSTAR140
                        If your refering to me.... Don't worry about being critical... I was hired to weld the beams in place, the engineer on the job ordered the steel and me and my crew attached it to the exsisting colls. The colls. were 8x40# and the beam was 24x94# , untill i have a PE stamp i do as i'm told there was a lot of stuff on that job that didn't seem right, but, in the end i got my check, so all is well
                        Kelly
                        Trailblazer 301D
                        2 XMT 304's
                        Spectrum 2050
                        XR with ALUMA-PRO
                        12RC suitcase
                        Millermatic 251
                        60a feeder
                        Ellis 1600
                        Bridgeport
                        16" southbend
                          Few more as progress goes on.
                          Here are couple more pics after the carpenter did his work at the car wash.And i added 4" more to the front of the lentil clips thanks to the engineers mistake they needed 11-1/2" to hold the concrete arch he had 8x4 angle. But now at least you can see it take shape.Told customer to paint all welds and exposed steel that did'nt get galvinized.
                          BB402D
                          TB300D
                          DIMENSION652
                          MM250X
                          MAXSTAR140
