Extension cord
  • Bert
    hehehe.....
  • SundownIII
    MAC is the expert here. If he says it's enough, you can take it to the bank.
    In my owner's manual for the MM 251 they specify a minimum conductor size in AWG of 8 with a maximum length of 127' (@230V). Your #6 AWG wire is more than adequate to power the MM 252.
    Relax and burn some wire.
  • fun4now
    wile i would tend to agree with MAC on it i would look in my manual, dosent it have a chart for cords and whats needed for what distance.
    i'll look around i think i have one but like mac said the 252 only pulls that at max and then for a short time.
    if it was mine i would go for it, but hey thats me. i'll see if i can dig up the chart if you cant find one in the manual.
  • MAC702
    First, he'll only pull 50A when welding at full-tilt. Second, his duty-cycle will keep him in check, even at that distance, which is really not that long, IMPO. Many runs even in residential settings are over 60 feet, and #6 wire is rated for more than 60A in many situations. I wouldn't even give this a second thought.
  • Bart
    I'm not a electrician, but 6/3 wire sounds to small for 50 amps over a 60ft run. Your going to have a pretty big voltage drop when you start drawing some high current. When I re-wired my detached garage, it was a 40ft run and I put 4 guage wire in and according to code I can safely run up to 70 amps.
  • MAC702
    That cord is plenty. Go for it!
  • kdavis
    started a topic Extension cord
    Extension cord
    I have a Millermatic 252-I was wondering if I could safely use my 60 ft 6/3 wire extension cord. I believe the welder comes with 8/3 wiring. Im using a 220 50 amp power source.
