Extension cord
  • Extension cord
    I have a Millermatic 252-I was wondering if I could safely use my 60 ft 6/3 wire extension cord. I believe the welder comes with 8/3 wiring. Im using a 220 50 amp power source.
    That cord is plenty. Go for it!
      I'm not a electrician, but 6/3 wire sounds to small for 50 amps over a 60ft run. Your going to have a pretty big voltage drop when you start drawing some high current. When I re-wired my detached garage, it was a 40ft run and I put 4 guage wire in and according to code I can safely run up to 70 amps.
      www.wmauto.com
      www.walshoriginals.com
      www.seabeastart.com
      http://members.fotki.com/Bart1971/about/
        First, he'll only pull 50A when welding at full-tilt. Second, his duty-cycle will keep him in check, even at that distance, which is really not that long, IMPO. Many runs even in residential settings are over 60 feet, and #6 wire is rated for more than 60A in many situations. I wouldn't even give this a second thought.
          wile i would tend to agree with MAC on it i would look in my manual, dosent it have a chart for cords and whats needed for what distance.
          i'll look around i think i have one but like mac said the 252 only pulls that at max and then for a short time.
          if it was mine i would go for it, but hey thats me. i'll see if i can dig up the chart if you cant find one in the manual.
          thanks for the help
            MAC is the expert here. If he says it's enough, you can take it to the bank.
            In my owner's manual for the MM 251 they specify a minimum conductor size in AWG of 8 with a maximum length of 127' (@230V). Your #6 AWG wire is more than adequate to power the MM 252.
            Relax and burn some wire.
            Syncrowave 250 DX Tigrunner
            Miller MM 251 w/Q300 & 30A SG
            Hobart HH187
            Dialarc 250 AC/DC
            Hypertherm PM 600 & 1250
            Wilton 7"x12" bandsaw
            More grinders than hands
              hehehe.....
              I'm not late...
              I'm just on Hawaiian Time
