Originally posted by FusionKing
View Post
What Amps To Mig Weld 1/6 Alum. Jetski Block
Originally posted by STEVE007 View Postwhat amps should i use ,thanks for the info
Did you get a manual with it?
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
If you decide to fully weld in the hole, remember this: when you're doing your practice pieces, weld on the edge, just like you'll be doing to fill the holes. If you practice on a solid piece, it will handle a LOT more heat than an edge. Then when you move to your case, the welder will be TOO hot.
I'd get some 3/16" or 1/4" thick alum and cut two pieces to fit the holes. Then you only have to weld around the perimeter. This will allow a larger margin of error (It won't blow a hole in the edge as easily).RETIRED desk jockey.
Miller Syncrowave 250.
sigpic
Make a tight fitting backing plate that the added filler metal can lay on. Use copper as the filler will not stick to it. Looks like the pump body and if so there will be less oil soaked into the metal. Clean, clean, clean and grind to fresh metal all the way around and clean well back from the edge inside and out. V cut the cracks then dril and fill a little hole at the end of each one
Good luck. I suspect that there will be a fair amount of test and tuneLast edited by Vicegrip; 11-10-2008, 01:41 PM.Weekend wannab racer with some welders.
Originally posted by Craig in Denver View PostI'd get some 3/16" or 1/4" thick alum and cut two pieces to fit the holes. Then you only have to weld around the perimeter. This will allow a larger margin of error (It won't blow a hole in the edge as easily).
Then you have the issue of what material to make your "patches" out of in the first place because you are welding cast to billet then and may have weld dilution/compatibility issues as well. Not to mention the hassle of accurately clamping it to tack on.
The copper backing idea is much better IMO but after 30 years of this I simply just weld the dang thing and grind it perfect. You're only welding an inch or two at a time. That little wire is like a surgeons needle when used in capable hands!
A curved piece of steel would be even better IMO for a backer but you have to go inside and weld any ways to tie in all the welding and eliminate any stress areas before you grind it.
If I was gonna go with a "backer" I'd probably use it on the outside and weld from the inside first and then weld the square sections up a bit more.
You gotta get the toes to wet out over the pores or you will have a perforated line around your work when ground to size. Then that could start a leak/crack in some cases (pun intended)
If I was going to use a piece of stock I would weld the cracks first and then lay the new pieces on the outside and weld them in from the inside 100% then weld the outsides also. but I doubt I would attempt to make a "part"...BTDT but then YMMV
Miller WC-115-A
Miller Spectrum 300
Thanks For The Great Info,just Received Mig Welder Today, Clarke 185 Spool Gun,hot Shot ,it Does Have Six Different Settings 30-150 [220] Should Be Able To Weld Just About Anything With It,will Make A T-top For My Boat In The Spring,shorten Radar Arc, Already Have The S.s. Tubing
FusionKing:
I didn't realize that MIG had that much control. For the OP, what filler would you use, 4043?
You gotta get the toes to wet out over the pores or you will have a perforated line around your work when ground to size. Then that could start a leak/crack in some cases (pun intended).
This is the OP's first MIG project and is why I joined the thread. Plus the frequent starts and stops. Funny pun.
Thanks for the detailed description. Spent my career at a desk , so I'm here to learn.RETIRED desk jockey.
sigpic
first time using mig welder
mig welding exhaust pipe,flux core .030 wireAttached Files
