Airplane Propeller
  • Airplane Propeller
    I had been looking for an airplane propeller for some time to hang up in my shop. One of my friends told me she knew where one was and that she would get it for me. I did not know that it would be bent. Any ideas how to straighten the prop? I thought about heat but I have never tried anything this big before. I was also concerned that aluminum of this size would dissipate heat rapidly. Any help would be greatly appreciated.
    Thanks,
    Nick
    Send it to Alaska
    Man, I've seen props on operational aircraft up here that weren't much better than that one.
    Send it To Alaska.
    Jerry in Anchorage
      Hang it up bent. A good, used propeller hanging on the wall is cool. A bent propeller is cool, and has a story.
        Tell people that you were in the plane at 10,000 feet when you hit a duck.
        RETIRED desk jockey.
        Miller Syncrowave 250.
        sigpic
          a really big duck. LOL
          sigpic
            As the Prop will not ever be in service again here is my take as I have repaired/ straightened a few rims and forward controls.
            You are definitely gonna need some heat and I recommend a nice oa set up with a rose bud.
            Heat that puppy to about 750 range and add a slow pressure to the bend. Not sure if a prop is hollow but if it is we are gonna have a issue and will need to sling/strap and pull the bend out.
            the key to success is use your common sense and take your time.
            Go slow and don't throw too much heat at it.
            The funny thing with aluminium is when you add the heat most of the bend will come out naturally. A little heat goes along way and I also use a raw hide hammer and it does wonders.
            Good Luck and give a shout if you need more help.
            Laurence
              Hang it up bent, it would be even more interesting if you found out the story behind it.
              But you always could make up your own!!!
              at home:
              2008 Suitcase 12RC
              Spoolmatic 30A
              WC-24
              2009 Dynasty 200DX
              2000 XMT 304
              Sold:MM130XP
              Sold:MM 251
              Sold:CST 280
              at work:
              Invision 350MP
              Dynasty 350
              Millermatic 350P
                There is an aviation salvage yard in Phoenix AZ I used to deal with for unusual aluminum pieces. I do not recall the name, but google them and you'll find it. Contact them and ask this same question. An aviation salvage yard might be a good start, or contact the aviation museaum at the smithsonian as they are always doing restoration they may have an idea how to accomplish this with the least fatigue on the metal.
                Peace,\
                Paul
                  Cool Prop
                  In all the years I flew, never got a bent one, but maybe the pilot forgot to extend the gear
                  Anyway it looks cool like it is, the advice given on bending is good, but I have no idea how well it works.
                  Good Luck, let the forum know what you did..
                  sigpic
                  Miller 140 w A/S
                  HF 90 Amp Flux Core
                  Dewalt Chop Saw
                  Smith O/A Torch
                  Ryobi, HF grinders
                  Harley Electra Glide Classic
                    Heat sounds like the way to approach this project, but I will be cautious and call some of the experts mentioned, in order to avoid any problems. If you have any other ideas please let me know.
                    Thanks,
                    Nick
                      Check with your local airport, ask about a prop shop.
                      Ask where they send their props. Shouldn't cost too much to have them do it as it won't be going on a airplane, if it was going to be put into service it would have to be balanced.
                        That'll take a lot of work to look like a good prop again. It does have some real character in its present state.
                          Most modern props are hollow, and some have a composite epoxy poured into the center for strehgth. You need to be really careful in doing that. Even the professionals at museums tend to just replace a prop in that condition. Find a manufacturer's name on it somewhere if at all possible and look them up, they can tell you about the construction technique used and give you the best probable method. My advice, as an aviation mechanic, is to either hang it bent, or remove the good blade and hang that alone. It will look as good, perhaps not as striking as the entire hub, but for your purpose, ****, anything is better than nothing right.
                            not to try and steal the thread but we got an old wooden one hanging in my dinning room from when my granddaddy worked at sensenich propeller here in littiz, Pa. This one is when they still made wooden ones the make aluminum ones now. this one is not airworthy.
                            http://tinypic.com/view.php?pic=16jg44&s=4
                            http://tinypic.com/view.php?pic=2rhsbiq&s=4
                            http://tinypic.com/view.php?pic=av4ytt&s=4
                            Dylan
                            RED BIRD WELDING
                            "Experience is simply the name we give our mistakes"
                            HH-140
                            Crappy stick welder
                            Victor supper range II
                            Makita grinder
                            more stuff i don't feel like listing.
                              Thanks for the advice. I was going to call a few folks before attempting to repair the prop. As for hanging the good blade...they are both bent. I will keep everyone posted.
                              Thanks again,
                              Nick
