Desktop Organizer
  • Desktop Organizer
    Here are two pictures of a desktop organizer that I recently finished. The first picture is as welded. The second is after bead blasting and in use.
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Nice
    are the sharp corners any problem?
    thanks
    frank
      Nice job! However, I store my Post-It notes all around my computer monitor.
      Syncrowave 180 SD
      *HF-251D-1
      *WC-1S & Spoolmatic 1
      PakMaster 100XL
      Marquette "Star Jet" 21-110
        looks like a fun project. i saved a pic, now i just have to have the time to waist to go out and make me one. man i gotta get more play time.
        thanks for the help
          Frank:
          Are the sharp corners any problem?
          The bead blasting takes off the sharp edges of the pieces that aren't corner welded. The corner welds make the metal wrap around the corners so they aren't really that sharp before bead blasting.
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DoAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Don, have ya tried running a bead down the sharp edges, looks great and no Sharpies left except in the Pen and Pencil slot.
            I use that trick when I have tubing to be deburred in and out, especially rectangular stuff....little bit of low amp Tig action and away ya go...
            Nice Job, Paul
            More Spark Today Pleasesigpic
              Good idea. I hadn't thought of it.
              Don
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DoAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
