How do you measure a weld thickmess? From the center of weld... or edge to edge?
Weld thickness???
Weld thickness is measured by both the leg legnth and the throat. A fillet weld has two legs with toes and a throat, a groove weld has a throat, toes, root reinforcement, and face reinfocement. A typical fillet weld will have a leg length equal to the base metals thickness and a throat that runs from the root and intercepts a line drawn from toe to toe. A concave surface between two toes (or edges) of a fillet weld can offer insufficient throat. A slightly convex surface offers sufficient throat and a little more, but too much is a waste of filler.
Fillet guages are available from most local welding supply stores and are a good tool for measuring welds.Jonny
Dynasty 300DX
Esab PCM 1000
wow, thats prity well put.i was just going to say it depends on the weld type called out in the prints. but his is much better.
thanks for the help
[email protected]
