Cracks in Aluminum Weld
  • Cracks in Aluminum Weld
    I've welded up my gas tank, and when I pressurized it up to check for leaks, I split a weld open. I've also noticed that cracks form very easily in other projects with just a bit of applied stress.
    Specs:
    .125" 5052 AL
    4043 filler
    TIG, 100% argon
    Whats going on?
    alum. cracks
    hey jpmassy i am not an expert but i would try 6061 with that filler or try
    5051? with 5000series alum. i am sure that someone with more exp. will jump in and we can both learn a new tip! good luck shoprat
      Lots of good information from alcotec (bought out by esab):
      http://www.alcotec.com/us/en/educati...um-Welding.cfm
      "Alloys possessing from 1% to 2.5% magnesium, such as 3004 and 5052, are very sensitive to cracking when using base alloy filler. Alloys with 3.5% magnesium and more exhibit low sensitivity to weld cracking. The use of a 5% magnesium content filler, such as 5356, to weld 5052 can provide a higher magnesium percentage in the diluted weld metal and reduce sensitivity to weld cracking. The more magnesium an aluminum magnesium alloy contains, the less likely it is to crack; thus, the high magnesium content fillers 5356, 5183, and 5556 are commonly used to weld both wrought and cast aluminum magnesium base alloys."
      Use 5356 next time.
      -dseman
        I have an overflow tank from canton that cracked just like that
        mm 210
        dynasty 200dx
          Specs:
          .125" 5052 AL
          4043 filler
          TIG, 100% argon
          Whats going on?
          The picture appears to have very little filler and a bunch of contamination.
          Griff
            I sorta doubt it was just filler that caused your problem. I've welded loads of 5052 with 4043 and not had any problems. It is not your first choice but it does a good enuff job that a crack such as that is not a common occurance.
            I think it is more of a lack of fusion judging from your pic. Looks like maybe moving to slow by the looks and it seems crowned a bit much like filler was added too soon as well. I would strive for more of a keyhole effect myself...That bead will weld with fusion alone. Aluminum will bridge across 2 parts easily without penetrating completely thru unless you make it hot enuff before adding filler and moving forward.
            What does the back side of the weld look like would be the question. I realize it is a tank tho, so you prolly can't see it. I would cut out the weld 100% and crank the heat more and let it get wetter before I moved forward. HTH
            Miller 30-A Spoolgun
            Miller WC-115-A
            Miller Spectrum 300
              That may be tearing from the root. Do you have a keyhole in front of your weld puddle while welding?
              Also, are your welds cooling too fast? Have you considered using a little preheat? That sheet of aluminum is an awfully good heat sink for sucking the heat away from the weld rapidly.
                Use 5356 next time.
                -dseman
                Interesting....thanks for the info.
                  Griff
                  I sanded and then SS wire brushed it. The edges are plasma cut, so that probably didn't help.
                    Hmmm....I might be watching for enough penetration. This is my 1st major AL welding project, so I was excited just not to blow a 1/2" hole in it.
                    I didn't think that preheating was required on such thin material?
                      "Plasma Arc Cutting, Beveling, and Gouging:
                      ยท This process has some limitations and must be carefully controlled. If it is used, it requires the power source to be set (DCEN) along with the use of small orifices to gain high velocity and concentrated heat. Heat affected zones will be crack prone particularly for 2XXX, 6XXX, and 7XXX series alloys and will require 1/8 inch or more of mechanical surface removal before welding. Series 1XXX, 3XXX, and 5XXX alloys are not as crack prone and can generally be welded as cut by this process."
                      From the Link
                      Ed Conley
                      MM252
                      MM211
                      Passport Plus w/Spool Gun
                      TA185
                      Miller 125c Plasma 120v
                      O/A set
                      SO 2020 Bender
                      You can call me Bacchus
                        roger that
                        I was gonna say that too. Unless you are using a shielding gas while plasma cutting, you have to remove most of the HAZ because of the high levels of oxidization that occur. Even when you use shielding gas vs. comp air, the oxidization penetrates more than you would think. Also, I would use a 5356 filler on a 50xx series aluminum. It also looks like you might need to use a little more balance to clean the weld better.
                        What machine are you using? What tungsten? Balled or pointed? Pulse?
                        SYNCROWAVE 200
                        Atlas 618 lathe (vintage 1960) reconditioned DC
                        Sioux 3/8 Pneumatic Reversible Drill
                        Makita Everything else
                        2400 square feet of Sanford and Son lookin shop space
                        "Once the spoon flys, putting the pin back in won't solve anything"
                        USA 15T, 15V
                        www.myspace.com/blackbird455
                        http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
                          Syncrowave 250dx
                          I believe I was using pointed 2% thoriated.
                          No pulse option.
                            Griff
                            Where?
                            1234567890
                              Uhh....
                              See it now?
                              The little black pepper looking flakes that float on the top of the puddle turn into stuff that looks like that. Also notice that the white "flash" on the outside of the bead is narrow, meaning only a small amount of DCEN in the cycle, balance adjustment might fix it, but like was said before, if it was plasma cut, there is alot of oxide present, and it needs to be removed before welding.
                              SYNCROWAVE 200
                              USA 15T, 15V
