Labor Pricing HELP
  • #61
    Originally posted by JTMcC View Post
    I don't know what "free standing archetectural canopies" are exactly.
    JTMcC.
    It's a fancy way to add a couple $$ signs to the word curtain rod, so yeah as far as the ROC is concerned I'm good because all I have to do is FAB them the client willl have them powder coated and they will sit free standing thanks for the link I'll add it to my list to check out
    MILLER 180 W SPOOL GUN
    MIller CP 300 w/S22-A Feeder
    Miller Syncro 200
    Miller 375 X Plasma
    Miller Elite Hood
    JD2 Bender
    Tube Notcher
    Horizontal/ Verticle Bandsaw
    Makita Angle Grinders
    Arsenal of handtools
    Evolution Raptor dry saw
    Single Stage 60 Gallon Compressor
    Delta Drill Press
    "No fear to learn by doing", and a degree in Redneck Engineering
    • #62
      Fine.. what my link no good
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
      • #63
        AHHHH too many links! I just have a word doc I have been pasting them into until I can get time (ya know after my day job) to look them all over
        Miller Syncro 200
        Miller 375 X Plasma
        Miller Elite Hood
        JD2 Bender
        Tube Notcher
        Delta Drill Press
        • #64
          The link I put up is the SBS checklist of every legal requirement to start a business in Arizona.
          I think my link is unbeatable Broccoli 1.
          JTMcC
          • #65
            JTMcC
            Only beatable by my link that IS the checklist- just trying save the fella some Clicking time
            It is the Link posted before the Avondale post
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
            • #66
              You 2 just gonna play swords or what?
              Thank you both for the links
              Miller Syncro 200
              Miller 375 X Plasma
              Miller Elite Hood
              JD2 Bender
              Tube Notcher
              Delta Drill Press
              • #67
                http://www.troutandpartners.com/team/jack_trout.asp
                Most marketing campaigns fail, because
                people do not understand competition.
                Its all about specialization. Being outstanding
                at one thing is far better than
                being just good at many things.
                This is one of the things that eats my lunch. It was simple to think that being good at something would win out in the end, not so. One of the things that make Picaso such a great artist, he died rich.
                • #68
                  New guy here but i thought i would jump in on this since it was something i had trouble with as well. I basically took a guess on my pricing and it ended up meeting right with some thing i got right from a book (after converting inches to hours) with some slight changes. The book is "The welders Handbook" By Richard Finch. He recomaneds a dollar an inch + 1 dollar a tack weld and say that it still seems to low.
                  After doing some SS 6'' pipe and some large commercial handrails i found his numbers to be right within what i charge, so i have adopted it to give 2 pricing modes to people depending on if i'm doing all the fab & welding or if i'm just welding
                  I run a "mobile welding" truck around as well and my pricing is as follows.
                  MInimum of 25 dollars wether it's just something small you briong to me or for me to drive to your location and just look at the job. Then if time goes into an hour the first 25 applies to the hourly rate of 40 dollars per hour. On a strictly welding job where all parts are trimmed and fitted i do the 1 dollar a tack and 1 dollar an inch of weld. Then if it's SS or AL i go 1.25 per inch, and then add another .25 cents if the SS requires back gassing.
                  I know this thread is rather old, and i didn't read all replies, but just thought i would put this out there for the OP and for anyone searching just to see what things are going at in my area. MOst other shops charge between 40 and 60 an hour respectively, but since i have no shop overhead because i'm based from a place that i already work and have a decent metal shop at home i try and stay on the lower end of the scale to hopefully gain customers and revenue. I've owned a painting business for over 5 years and just this past year took welding to the "retail/commercial" level and so far things are good, business is picking up fast and i haven't been dissapointed with the money i've made on any project so far. Save for one recent job where i wasn't told of a 4 day deadline on 115ft of mild steel handrail set in concrete. When i wrote the bid they acted like i had all the time in the world, so i gave them a good price to get my foot in the door. But, i still came out at 30 bucks an hour afer all was said and done.
                  Sberry has a good point, I specialize in automotive/motorcycle fab & repair work and keep my rigs out at the track every weekend, I probably don't make as much as some one welding pipe for a living or just having "the weld shop" on the corner that does "whatever" and that's made the jobs that i do get very pleasing to work on and keeps the pay scale good. There's a lot of mobile welding shops in town (3 others) but by going to the track and talking with the other racers and showing them my work i broke into orking on a ton of drag bikes locally, everything from starter carts to wheely bars and Frames. I also specialize in CRMO4130 and ALuminum work because i like them so much more than all other metals and I practice every joint & weld position and burn through every bit of filler rod i can on these metals when i'm not working on a customer project so that i will have experience in every situation posible when it comes to these metals and so far it's all paying off very well.
                  Hobart Handler 135
                  Smith MB55A-510 O/A setup
                  Lathe/Mill/Bandsaw
                  Hypertherm Powermax 45
                  Just about every other hand tool you can imagine
                  • #69
                    Hmm very interesting, and deffinately worth a look I'll compare it up to the last couple jobs I've done and see how it works out for me. Regardless thank you for the input I appreciate it.
                    Miller Syncro 200
                    Miller 375 X Plasma
                    Miller Elite Hood
                    JD2 Bender
                    Tube Notcher
                    Delta Drill Press
                    • #70
                      Nice Response!!
                      Originally posted by FATFAB View Post
                      As you can see I fixed the issue of where in the world I am, thanks for pointing it out.
                      Underbid all you want, just play on the same field as the people you are competing with. If the people you are taking work from are not licensed bonded and insured then more power to you.
                      Clearly that is not the case, or you would have humbled your self.
                      I did start out day one with a bond liability insurance, work comp insurance, followed two weeks later with the two licenses I need. Total spent $1900.00.
                      Bye.
                      Wow!!! You are angry. Find somewhere elso to go, maybe Alaska?
                      Millermatic 210
                      Syncrowave 200
                      Spectrum 625 X-treme
                      Hobart Champion 16 W/
                      Miller 8VS Suitcase
                      Miller 3035 Spool Gun
                      Tons of Tools
                      Microwave
                      Laptop and Printer
                      Speakers in the Back for all to hear Sirius Radio!
                      • #71
                        What's up with that?
                        Bye.
                        That guy was pissed!!
                        Millermatic 210
                        Syncrowave 200
                        Miller 8VS Suitcase
                        Tons of Tools
                        Microwave
                        Laptop and Printer
                        • #72
                          Nice Response!!
                          Bye.
                          Wow!! You are angry. Maybe, you should move to a non-populated place like Alaska!
                          Millermatic 210
                          Syncrowave 200
                          Miller 8VS Suitcase
                          Tons of Tools
                          Microwave
                          Laptop and Printer
                          • #73
                            I didn't see all of the "anger" in the post, but maybe it was there. I did notice the he posted some info about how he started in business, as per the OP questions.
                            • #74
                              I don't see the anger, but I don't try to read into posts more than is there.
                              JTMcC.
                              • #75
                                Might be she is just stirring up the poo?
