Labor Pricing HELP
    nfinch86-CANADIAN WELDOR :
    BYE THE WAY, That Old LINCOLN on my truck has been around Almost as Long as me , I Checked the serial #'s Built in 1968 it starts First Time Every Time with Old Rope Pull Start !! Norm:
      Originally posted by FATFAB View Post
      Underbid all you want, just play on the same field as the people you are competing with. If the people you are taking work from are not licensed bonded and insured then more power to you.
      Clearly that is not the case, or you would have humbled your self.
      I did start out day one with a bond liability insurance, work comp insurance, followed two weeks later with the two licenses I need. Total spent $1900.00.
      Bye.
      Ok I did some research, just to be clear, as you can see I'm in AZ. Do you happen to know what I need to be legit in AZ? Well I do so I'll let you know. Nothing, if I bill out more than 10k a year which I haven't as of yet, I need a bussiness license and that's only for tax reasons. As far as the bonding, (which is basically and additional guarentee that I stand by my work) no I don't have that, but if there is ever a problem or an issue with my work, my word is my bond and always has been. So if there was an issue and I had to eat a job for whatever reason, guess what, I don't need a piece of paper that forces me to stand by my word, I just do, that's how I was raised.
      My father is a painting contractor, a liscenes and bonded contractrator at that and a small bussiness owner. He is bonded because most of his projects require it. If the customers I did work for required it of me then it is something I would do, but as of now they don't so I will continue to keep my overhead as low as I can.
      To address you undercutting claim, I bid a job for materials and how long it's gonna take me, there was a time when I referenced competitiors bids to give me and idea, by the way thats called staying competitive. If your always high your not gonna get the work, same thing if you lose your a$$ every job you'd probably rethink how you bid things.
      So as far as your black and white issue as it pretains to local laws I know I'm right, and you may be right in your neck of the woods but if your gonna roast somebody do the research first.
      MILLER 180 W SPOOL GUN
      MIller CP 300 w/S22-A Feeder
      Miller Syncro 200
      Miller 375 X Plasma
      Miller Elite Hood
      JD2 Bender
      Tube Notcher
      Horizontal/ Verticle Bandsaw
      Makita Angle Grinders
      Arsenal of handtools
      Evolution Raptor dry saw
      Single Stage 60 Gallon Compressor
      Delta Drill Press
      "No fear to learn by doing", and a degree in Redneck Engineering
        Originally posted by jallcorn View Post
        Sometimes I charge by the hour, that is pretty simple, hours * rate plus materials plus a markup of about 25 to 50 percent on materials.
        So, I "ball-park" it based on how long I think it will take. I look at how much I'll gross minus materials and make a decision to bid the job or not. If I get the job, I do the absolutely best job possible... design, construction, finish. If I think it will take 250 hours and it takes 400. Tough on my part.
        I don't want all the business, I couldn't do it all anyway. I have no competition other than the big companies that farm their work out to Mexico. My work is my signature and my customers are always satisfied.
        Agreed I don't think there's a guy (or girl) out there that hasn't drop the ball and lost their *** on a job at some point. Things happen. Thanks for the contructive advice
        Miller Syncro 200
        Miller 375 X Plasma
        Miller Elite Hood
        JD2 Bender
        Tube Notcher
        Delta Drill Press
          Originally posted by Broccoli1 View Post
          Do you need to be bonded and insured by law?
          Nope, not here anyway can't really speak for other parts of the country though
          Miller Syncro 200
          Miller 375 X Plasma
          Miller Elite Hood
          JD2 Bender
          Tube Notcher
          Delta Drill Press
            Originally posted by nfinch86 View Post
            TO EACH HIS OWN! Survival Of The Fittest. Go For It Man!!
            Thanks Norm, and Ed's right real nice site ya got.
            Miller Syncro 200
            Miller 375 X Plasma
            Miller Elite Hood
            JD2 Bender
            Tube Notcher
            Delta Drill Press
            • #21
              Ok, how about this, figure out how long you think its going to take, double that and add 30%.
              • #22
                Ok, so what if a guy has been plotting and planning to start his own little bizness for several years now, and he's been paying attention, taking notes, and knows how long the job will actually take.
                Will that formula work for that dude???
                JTMcC
                • #23
                  I give good luck
                  • #24
                    JTMcC
                    Sure it will.
                    ... since we do not have a figure for Hourly/Day rate - as the Op inquired about, "Is there a going rate for labor...", the formula is rather useless.
                    Ed Conley
                    MM252
                    MM211
                    Passport Plus w/Spool Gun
                    TA185
                    Miller 125c Plasma 120v
                    O/A set
                    SO 2020 Bender
                    You can call me Bacchus
                    • #25
                      SinGear: Thanks, For someone JUST STARTING you got yourself some Gear. As I said ; GO FOR IT MAN !! Norm :
                      • #26
                        Sure it will.
                        Thanks for your support.
                        That "going rate" thing is pretty important because the locals who've been in business for years know what it takes to survive long term in that marketplace.
                        I've been in business since 1992 and i've watched (literally) over a hundred start ups come and go in my little rural area. 99% of then charged too little. None of them charged too much.
                        You can undercut the local market and pick up "junk" work for a short period, but any company that has serious money to spend on outside welders knows that a real company, doing real work with real welders has to charge a certain rate. And they'll throw out low ball offers. If your rates aren't real world, companies won't take you serious.
                        If I can't make a good living, have good health insurance with dental & eye care, and stash away enough to live comfortably in retirement, then I'm not interested. And I started out completely legit, with a whopping investment of $1800 dollars (1992 dollars, made with a stinger in my hand) and two small children. I was the sole income for my family. If you can't pull the pin then you don't have any business in business.
                        It can be a very harsh world and these guys that operate "part time" welding outfits so they can post as experts on the internet don't have a clue what it takes to provide every $$$$ of income for a family with a stinger in your hand, thay are in my opinion phoneys. Fortunes are made and lost every day in this business, but not by people with a "day job".
                        Anyway, that's my take Mr. Broccoli
                        JTMcC.
                        • #27
                          After reading JT's post over a couple of times, he pretty much covered it all...
                          Later,
                          Jason
                          • #28
                            Niice somehow I'm thinking that equation might not work out so well for me. But hey I could always give it a shot
                            Miller Syncro 200
                            Miller 375 X Plasma
                            Miller Elite Hood
                            JD2 Bender
                            Tube Notcher
                            Delta Drill Press
                            • #29
                              I give good luck
                              And I wish you all the sucess in the world, no worries on your clients I don't do out of town work.
                              Miller Syncro 200
                              Miller 375 X Plasma
                              Miller Elite Hood
                              JD2 Bender
                              Tube Notcher
                              Delta Drill Press
                              • #30
                                Thanks Norm, the equipment is really any and all profit I have made on every job I've done, I pay the material and consumable bills a little to the wife to make her happy and then tools, more tools, anything that might make it just a little bit easier the next time, I never do a job without buying at least one tool
                                Miller Syncro 200
                                Miller 375 X Plasma
                                Miller Elite Hood
                                JD2 Bender
                                Tube Notcher
                                Delta Drill Press
