I'd scrap the jib crane idea and build an A-frame, on wheels for mobility, and hang a chain fall from it, use a beam trolly if you want to be fancy. A come-a-long will work if that's what you have.
You can put car wheels/tires under these for easy mobility in dirt/gravel. If your loads are very heavy (way over what you are considering) you can mount screw down pads to take the weight off the tires, and level the whole thing (that's important if you have a beam trolly, not so important if you don't).
I've made several of these, you can size them to fit thru the garage/shop door, or you can make telescoping legs so the height will adjust enough to go into/out of your shop. It's basically a free standing/more versatile bridge crane.
You can build these as large or small as needed.
Store bought models will give you a very good idea of what size material you need, your capacity is going to be very low so it would be easy to build in a serious safety factor. Run it by an engineer if you have doubts, an hour of an engineers time is pretty cheap if it lets you sleep at night.
These can be built to handle loads in the hundreds of tons, your application would be very simple.
Load test the thing to say 125% of your rated load and be happy.
Never get under a suspended load, and be happy.
Paint it a groovy color and be happy.
JTMcC.
JTMcC.
