bobcat 225 and tig alum
  • fabricator
    I hope after 7 months he figgured it out.
  • Speedddy
    ALum
    I welded it with a XMT 304 at work with Helium.We didn't have a hight Feak.Which I do at my shop.I got a Syncrowave 250 DX with a watercooled rig.Miller 252,Miller 140 and 2 other machines/ 675 plasma.Fixing to get Trailblazer 302.My coworker is the one who shown me You could use helium.I tried it I really didn't like the way it welded it wasn't as clean like my new Syncrowave 250 DX LOL
  • SundownIII
    The copper sheet was used for starting an arc in DC Tig welding. Does not contaminate the tungsten as even steel will. Generally used on machines without a lift-arc feature.
    As has been mentioned, Hi Freq is required for AC Tig welding. Without it (except for the inverters) the arc will extinguish as it passes thru 0 when switching from DC+ to DC-.
  • FusionKing
    Originally posted by retiredIW View Post
    it supposedly dont eat the tungsten
    I do not doubt one bit that there is a place for the copper thing...I have heard it as well but it is not used for aluminum. Trust me I did about 10 years on a 225NT Bobcat with an old Linde Freekbox and a #26V torch with a valve and pure argon. That is the minimum you will get by with unless you can score lab grade helium for using DC EN.
    You should just find someone with a spoolgun or hire a pro to tig it for just welding one item.
    Bring your stuff and come on down to my shop and I'll do 'er for free
    I like to shoot the bull with old welders
  • Guest's Avatar
    Guest replied
    You can DC tig aluminum......why wouldn't it work with the Bobcat?
    Originally posted by fabricator View Post
    Thats a new one for me.I think you were misinformed.However you will need high frequency a/c in order to tig aluminum.
  • Speedddy
    alum welding
    You can use Heilum to weld alum But it's not as clean.Rent a bottle for a month will it be cheaper.
  • fabricator
  • retiredIW
    why copper
    Why copper?
  • retiredIW
    conversion to cold smoker
    Originally posted by Craig in Denver View Post
    I hope you're only making something decorative. There's NO welding allowed on any high pressure cylinder. Not even during manufacturing.
    it is to be part of a cold smoker no pressure
  • Craig in Denver
  • fabricator
    Why copper?
  • BC Iron works
    you need a high-frequency arc starter and stabilizer
    like the miller HD-251 to weld aluminum with the bobcat
    they run around $1000.00
  • retiredIW
    started a topic bobcat 225 and tig alum
    need to tig an aluminum oxygen cylinder base back on to cylinder what setting to use with weldcraft tig torch and argon gas.i know i have to scratch start on a piece of copper, it is 3/16 thick aluminum. machine is bobcat 225NT
