The digital elite series has a Lens Power control of Manual-On and Auto-Off... What do they mean by Manual on? Is it still auto-darkening? I'm sure it has to be. Someone enlighten me, I am a bit confused.
New Miller Hemlets???
Originally posted by Lucky View PostThe digital elite series has a Lens Power control of Manual-On and Auto-Off... What do they mean by Manual on? Is it still auto-darkening? I'm sure it has to be. Someone enlighten me, I am a bit confused.Last edited by Icarus; 09-11-2008, 08:27 PM.
You have to turn the helmet on as you start to work, not before every weld. If some minutes go by without use the helmet will turn itself off.
I haven't used the Miller model, but I think it is always dark if the power is off. Turn the power on and you have an auto-darkening helmet. If several minutes pass without use it will shut the power off again.
These helmets may leave the power on if you set it on the bench looking at a bright light on the ceiling (I THINK...)"If you build it, they will come!"
Originally posted by Marcel Bauer View PostYou have to turn the helmet on as you start to work, not before every weld. If some minutes go by without use the helmet will turn itself off.
These helmets may leave the power on if you set it on the bench looking at a bright light on the ceiling (I THINK...)Owner of Burnt Beard Fabrication & Welding Ltd.
BigBlue 500D
Millermatic 211
4' Box and Pan Break
IR compressor
