Plasma screen stands
    Originally posted by chris***@sbcglo View Post
    Good explanation.
    Now someone show me a picture with some 5" x 1/8" (or equivalent) material.
    Don't bother. I'll post them myself.
    Ed, I don't like you anymore and you're not welcome to S.D.
    Funny thing (in a not so funny kind of way) is that I've made countless tables before that required skirts and I always rolled them in one piece. In fact, I was planning on rolling these the exact same way I've always done in the past, which was in one piece. So, I make my own [email protected] roller for wider, heavier material and I've lost all my marbles somewhere along the way. I actually took the last six months "off" because of the "accident", and my wife always says I haven't been the same.
    Excuse me while I throw this project in to the recylcing bin along with taking a plasma torch to my roller. One person says it should be rolled in two parts, and I'm a lemming.
    I've gotta go and do twice the work I should be doing
    I'm really mad at myself.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
      Originally posted by Old Sporty View Post
      Chris*** - Just a question. Why do you have to roll the rings in halves?
      Thanks.
      ... because I like to make extra work for myself.
      I'm an idiot.
      Maxstar 200DX
      Maxstar 300DX
      Passport
      Spectrum 701
      LMSW-52 spot welder
        Chris-
        Sorry wasn't trying say you can roll yer 5" this was- just trying to show the Flat areas that happen when rolling material in these style Rollers.
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          Originally posted by Broccoli1 View Post
          Chris-
          No, I'm serious. I already rolled one in one piece. I really am an idiot.
          I'll post pics later.
          I quit.
          Maxstar 200DX
          Maxstar 300DX
          Passport
          Spectrum 701
          LMSW-52 spot welder
            I quit.
            Don't worry, it takes our kids at least till they are 4 to realize it
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
            • #21
              My technique has always been to measure out and mark the circumference on the material and leave enough for tails, then roll it till the lines are close enough together.
              Syncrowave 250DX
              Invison 354MP
              XR Control and 30A
              Airco MED20 feeder
              Thermal Dynamics Cutmaster 81
              Smith O/A rig
              • #22
                Chris - That's the reason I asked. I've always rolled in one piece and accounted for the flats as Broccoli said. Just thought I might learn a new and better way of doing it.
                Thanks.
                • #23
                  I've always done the same thing for one piece, too. In fact, all my planning was to do this project with one piece rings, just like every other freakin' ring I've ever rolled. Then somewhere along the way I lost my mind and listened to someone who would have done them in two halves. In fact, I even had the material all scribed up for one piece.
                  At go time, I cut everything in half, and the rest is my PITA.
                  I'm so beside myself I want to cut these ones up, buy new material and start over. Anyone want a roller?
                  I need to take another six months off... ... but I gotta eat.
                  I'm done posting. You'll all never hear from me again.
                  Maxstar 200DX
                  Maxstar 300DX
                  Passport
                  Spectrum 701
                  LMSW-52 spot welder
                  • #24
                    I will say this: it was tough to get the one piece ring out of the roller, and with material 3/16" and up, one would have to remove the top roller to get the ring out, or you're in for a fight.
                    I swear I've lost my mind.
                    Maxstar 200DX
                    Maxstar 300DX
                    Passport
                    Spectrum 701
                    LMSW-52 spot welder
                    • #25
                      Don't be so hard on yourself. You did something new and made it work didn't you?
                      As for the ring roller, PM me and we'll make arrangements for the transfer.
                      • #26
                        more pics, finally
                        Hello everyone.
                        I've been real busy, so I'm finally getting around to posting some more pictures (if anyone really cares).
                        1 and 2) Jigged up for welding the vertical tubes. The tubes are 3" x .120 wall. I had the 3/8" plate waterjet for a press fit so I could do the welds on the underside. I used this table to jig it all up square.
                        3) This is how the underside of the stands looks. Basically this is what I see before I weld the tubes. No one will see any of this, except some bugs or really small people.
                        4) Welded. All of these welds were done as jigged up, so it was good practice for OOP stuff. Although, it seems that most of my work is OOP.
                        5) Zipped up. I needed full 60" lengths which I got from 20' pieces. The ends of each 20 footer were creased as you can see in the photograph. I put it towards the backside and the pictures shows it to be much worse than it is in real time. No big deal.
                        Thanks for looking.
                        Maxstar 200DX
                        Maxstar 300DX
                        Passport
                        Spectrum 701
                        LMSW-52 spot welder
                        • #27
                          1) Stacked up. There were eight of these in total.
                          2) I TIG welded the seams of the skirt and buffed them out. I can control the fill better with a TIG weld so there's less post-weld grinding on a joint like this. I just welded these up as they sat stacked on the cart in the previous pictures. Not the prettiest welds, but I was cruizin' for speed and gettin' er done.
                          3) Mounting plate welded across the tubes. This will receive another bracket from which the monitor will hang.
                          All in all, this project came out pretty well. It wasn't my design, but I was happy to oblige. I'll try to get some pictures as they sit painted and installed once the building is finished. I'm just glad they're gone and I can move on to the next project.
                          Thnaks for looking.
                          Maxstar 200DX
                          Maxstar 300DX
                          Passport
                          Spectrum 701
                          LMSW-52 spot welder
                          • #28
                            For Broccoli
                            ...sometimes the bear eats you.
                            1, 2, 3) One piece ring. Ahhhh, geeeeez.
                            Maxstar 200DX
                            Maxstar 300DX
                            Passport
                            Spectrum 701
                            LMSW-52 spot welder
                            • #29
                              I think they turned out pretty good.
                              Are the seams at the edge of the plate/rings going to be left visible, or will those be filled by the painter?
                              Syncrowave 250DX
                              Invison 354MP
                              XR Control and 30A
                              Airco MED20 feeder
                              Smith O/A rig
                              • #30
                                The skirt was tucked under the edge of the plate by 3/16", so the seam won't be visible unless you're less than 5" tall.
                                Glad it's done.
                                Maxstar 200DX
                                Maxstar 300DX
                                Passport
                                Spectrum 701
                                LMSW-52 spot welder
