Homemade press brake
    What actually operates the down motion?
    Can one of these be used with a hydraulic car jack? I'm very new with metal, but know that something like this would be kinda essential...but can't figure out how the pressure is applied I know, I got a long ways to go
    Millermatic 212
    1998 Heritage Springer
    Kioti DK55
      shopoutfitters.com at one time offered one using a bottle jack. They used a 20t and used a pair of return springs to return the cylinder. Looks like they upscaled their unit and don't offer it anymore.
        For those who would prefer a dedicated press brake instead of a press and a brake.
        Not my work - pulled down off this site or the Hobart site - but from my files.
        I went with a press and a brake myself.
          Thanks Eddy, that's what I wanted to know.
          Millermatic 212
          Kioti DK55
            Metal Brake Complete
            JAMSCAL,
            I finally built the press brake this PM, except for paint. Successfully bent a piece of 5" x 1/4" flat plate 90 degrees. Bent some thinner .125 stock earlier as a test. Worked fine. My punch is 5" x 17" x 1". I cut it earlier on the track torch, then had my brother in law finish it on his mill. I think maybe the heat on the track torch had it a little wavy. I won't do that again. Bottom plate is 3/8" x17" x 11", spacing on bottom dies is 1 1/2". They are 1" square stock. My press has a 7 1/2" spacing on it and I am wondering if I should put two or three braces across the bottom plate for support. I really was tired of using a vise, hammer and heat.
            I think Big Eddy posted a small bench type bender using a 4 ton jack. I think that will work fine for smaller stuff if I do not feel like lugging the break out to the press. He kindly listed plans as well so thats next project.
            OBTW, I have $8.00 in my press brake. Two springs and two bolts. I used 3/4" bolts, should have stayed with 5/8". I'll post a pic tomorrow.
            Thanks for your post. Lots of great ideas and advice on this site.
            Geezer
            Miller 175
            Power MIG 255c
            Ranger 8
            1974 Wisconsin 5K AC Only (Cherry)
            Spool Gun
            185 TIG
            Victor/Harris O/A
            • #21
              bottom die
              I plan on bending 1/4 steel plate either 3 or 4 inched wide to about 45 degrees. Can I just use solid 1 inch bars for the lower die? What's the spacing if all it will ever do is 3/16 and 1/4? I read somewhere the dies need to be hardened but only for more repeated use. I might even weld in a piece of this ground and polished rod to the upper die for a smoother radius.
              • #22
                Thats awesome! how much did all the metal cost?
                Miller Maxstar 150 STL
                Miller Millermatic Passport Plus
                Thermal Dynamics Dragun Plasma Cutter
                Protect your seccond ammendment rights! Join the NRA!
                • #23
                  has anyone built the mini bender big eddy so kindly posted? I'm interested to see what it can do thickness wise.
                  Millermatic 211
                  Spoolmate 100
                  Lincoln Weld-Pak 100
                  Hobart AirForce 400
                  Harris D-85
                  • #24
                    Lower V size
                    jdubb bottom die
                    The gap between the lower blocks should be approx 8 times the thickness. eg i/4 tk stock should be folded in a block about 2" appart. thats not to say you could not fold slightly thicker plate but doing this increases the chance of cracking and when folding thinner material youl get a bigger radius on the fold than you would like. Best of luck . Hope this helps
