Need ideas for welding table
  • Need ideas for welding table
    hello, I am a new member and after reading the project board for about the last week to get ideas on my new table i thought i would join and ask for some.
    I am building a 36"x27"x3/8" welding table with a fold up 12" extention on one end and 12" fold up cutting grate on the other (i have limited space so i want it to be somewhat colapsable.) it will also have a craftsman intermediate style tool chest mounted under the table top for storing tools and i was also considering a reciever style setup to accept a vice/bender or other misc. attachments that could be mounted to a plate and then slid in and removed to acomidate the job i would happen to be doing. (i got the reciever idea off of the message board) any sort of ideas or advice would be apreciated and i will try to get some pics posted of what i have so far.
    thanks, Nick
    HAVE...
    Hobart 135 (set up for gas)
    Victor torch
    DeWalt chop saw
    LUST....
    Syncrowave 200
    Spectrum 375
    Millermatic 210 or 251 (preferably the 251 )
    Height is personal preference. My table is 32" from floor to top. For most things it works well for me. Did a tig job the other day & I wished it was a little taller. Mine is 1" thick 48 x 96 top with 4 ship channel frame & legs. 6" hd casters for mobility. Make sure you leave a lip of a couple inches all around so it is easy to clamp stuff to.---MMW---
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      My table is also about 32" . This seems to be a good all a round hight. I have worked on 36" tables and found them to be uncomfortable , especially on large projects. Then again, I'm a short person so it all comes down to personal preferance. I drilled and threaded holes for my vice and other equipment so it can be unbolted easily without haveing to hold a nut on the other side.
      My sincere thanks , Pete.
      Pureox OA
      Westinghouse 300 amp AC stick
      Miller Syncrowave 250
      Hexacon 250 watt solder iron
        I've found 32-33" to be a pretty common height for tables. We just built a couple 4'x8' tables for our school shop out of 1/4" top plate, 4" channel (1/4" wall) for the frame/crossbraces and 4" x 4" (10 gauge) for the legs, plus 1/4" plate for gussets on the legs. We also welded on HD braking casters so we can move them around the shop. Seem to work well and heavy enough for our use. May someday through another 1/4" plate on top...but not anytime soon...I'll see if I can dig out the digital camera and snap some pics soon..
          If you're tall go a little higher
          32" is pretty much the standard height, but if you're taller than average, go a little higher, your back will love you. I'm 6'3 and my table is 34". It keeps me from hunching over that little bit. Anyone who's tall will know what I'm talking about. I end up getting a sore back just doing the dishes, but with just a couple of extra inches on my table, I can weld all day. I even custom built my own desk for my office that sits 1" taller than standard. It forces me to sit up proper in my chair, so I don't hunch over my keyboard.
          That's what's great about us fabricators, if it don't work right for us, we can make it!
          The difference between No One. and No. One is where you put the period. John Force
            I think the reciver idea will be a plus you could mount a female pice in the up-right position and the weld a mail piece on a plate then bolt your vise to the plate. just drop you vise in the reciver and their you have a vise on the edge or side of your table
            this way you can move it if you need to.
            also you can get 4 big nuts and bolts, like inch and a half bolts and nuts
            weld the nut to a plat and screw the bolt into the nut, mount the plate on the botom of your leg of your table and then if the floor in your shop,work area is uneaven you can turn the bolts to eather raise or lower the table to compinsate for the floor and then your table will be level (note table will be sitting on bolt heads) and you can level it where ever you put it.
            if you were to mount your table on casters you could make it where your bolts could be screwed down low enuff to rase it to level it.
            I hope all these ideas help you to make a great table
            have fun
              Thanks everyone for the info so far. I think that 32" sounds like a good hight i am a pretty short fella so that should work out for me. i am also planning on mounting casters to the legs and having screw down feet to lift it off the casters and make it stationary and level. my next challenge will be designing the mechanism to hold the folding ends up. i will try and take some pics and post them tomorrow (2-9-06) to explain what i am up to here.
              i am also considering a HF compact bender which is on sale for $49.99 on the net right now and adding the scroller attachment...i know that the scroller takes a little work to get opperable but the SO one is out of my range for now but i was wondering if anyone had anything to say about the HF compact bender (pos or neg) any coments would be appreciated.
              Thanks again and weld on ! Nick
              HAVE...
              Victor torch
              DeWalt chop saw
              LUST....
              Syncrowave 200
              Spectrum 375
                Weld table
                I have 7 welding tables in my shop all are 4'x8'x36" tall it seems to work well for all my weldors one of my weldors is 5'-4" and the other is a whopping
                7'-1" man.Now the cairs are adjustable hope this can help.and "good luck"
                "Molten Metal Fusion Technician"
                  I built mine at 35-1/2" tall, I am 5'10-1/2" tall and it seems to be just right for me when I am standing. I did need to add an extension to my stool as it was a bit short, that made the foot remote just reachable. I thought about a reciever and I have one that came off my truck, but I decided aginst it as my bench bender is mounted on a 3" thick maple block workbench that is 15' long and lagged to the floor and the wall. I havn't done any threaded holes yet as I have not used the table enough to know where they should be drilled. I have 5" casters bolted to plates that are welded to the bottom of the legs that are drilled to lock in all four directions, as I won't be putting any sideways tourque on it, and the weight of 300 lbs, that seems enough so far. After I use it more I may want to add some drop down bolts for more stability.
                  Regards, George
                    George,
                    That 35-1/2" height is from the floor and not the castor plates, right?
                    Thanks,
                    LJ
                    MM210 w/3035 Spooler
                    Stars & Stripes BWE signed by Andy
                    TA185TSW w/Miller Radiator 1
                    Miller Spectrum 125C
                    Parker Plasma 40
                      I have one of those benders and its not bad for what it is. The scroll bender is designed to use 3/16 material and wont acsept any thing thicker and thinner material is dificult to use in the scrroll attachment. There is a slot that you put youre metal in and any thing over 3/16 wont fit and any thing under 3/16 slips out unless you shim it up. But it does a nice enough job on the 3/16.
                      Pureox OA
                        Welding Table
                        HelloIve been welding for a few years and I have built several tables all are about 32 inches high
                        the best thing I have built onto them is a sliding tool holder on all 4 corners this is a tube inside a tube that makes the table frame
                        I slide it out to hold my Lead or Vise Grips or C clamps
                        when I need it when not needed I slide it in hidden from view and also doesnt interfere with top of table, these sliding tool holders also serve as a torch table when I slide them and locate a piece across both of them so slag will fall to floor.
                        I also have a shelf at about 10 inches from floor for fixtures and a smaller one about 6 inches from top for grinder or other tools
                        I will post a pic as soon as I can remember to take it with me to the shop
                        also I have an air hose hanger next to my blue print table and on the other side I have Oxygen acetylene bottles with a hose and torch holder"
                        the hose reel is on a stand and it also hold my 4 1/2 grinder on a piece of 4 " channel
                        keeping out of the way hope I helped you some what
                        Santiago Nunez
                          Sliding tool holder
                          when I need it when not needed I slide it in hidden from view.
                          Santiago Nunez
                          I'm glad you shared this..I really like the sliding tool holder idea. I'm planning on building a new table this spring and I'll pencil this into the sketch.
                          Thats what's nice about these forums..you can get all kinds of good ideas from fellow members that already have something you're needing adeas on.
                          Thanks again, Farris
                          Gone But Never Forgotten!
                            Santiago Nunez
                            Sounds like cool ideas. I'm a "visual" guy though...I'd like to see some pics!!
                              yeah i am a visual man also. i cant wait for the pic's of that table you built.
