Help Round pipe in tank
  • Help Round pipe in tank
    How do I make a precision fit of a 3 inch round pipe into a round tank?
    I need a 3 inch round pipe installed in the 24 inch round tank. I Need the pipe to perfectly vertical but it will be offset a bit from straight up on the tank if that makes sense. Instead of being just straight down into the center of the tank it will be offset to one side just bit.
    Just because you have one, doesn't mean you have to act like one.
    Miller 212
    Hobart 135
    Miller 375 X-treme
    Really antique Sears Arc N Spark
    O/A Torch Setup
    Drill the hole holding the bit in line with the intended angle of the pipe to be installed. The resulting hole will look oval but the pipe will fit when at the same angle.
    Weekend wannab racer with some welders.
      The other way would be to cut the 3" pipe to fit and then trace around it with soapstone and cut the hole with a torch.
      There is a site that has a program to make patterns for you, I don't know if I can find it though. You can also make your own pattern but its hard to explain how to do it.
      This came up a while back on this site and I did my best to describe how to do it and someone else posted a link to the site with the program. You might try the search on this forum to find that thread.
      My sincere thanks , Pete.
      Pureox OA
      Westinghouse 300 amp AC stick
      Miller Syncrowave 250
      Hexacon 250 watt solder iron
        Check out this site if you want to try making your own pattern. I thought I had one bookmarked.
        http://www.thesheetmetalshop.com/pdf...book_part1.pdf
        Pureox OA
          How precision?
            Just out of curiosity whats in the 24 inch tank
            piper
              thats an awesome link. thanks!
              Millermatic 180 Auto Set
                  Your welcome. The sheetmetal shop is one of my favorite sites beside this one. They have a lot of reprints of old books from around the turn of the 20th century. I ordered the DVD of old books and its great, I definitely recommend it.
                  Here is a link to the site if you want to poke around a little.
                  http://www.thesheetmetalshop.com/index.html
                  Check out the library, you'll find some interesting reading there.
                  Pureox OA
                    Thanks guys. I book marked the site. The tank is going to be a smoker. The pipe is the exhaust stack.
                    Miller 212
                    Hobart 135
                    Miller 375 X-treme
                    O/A Torch Setup
                      doesnt need to be precision then, any method, burn it with a torch.
                        Yeah, I was more concerned about making a pattern to cut it out from than how to cut it. I didn't want an egg shaped hole that I had an inch on one side or the other to fill in.
                        Miller 212
                        Hobart 135
                        Miller 375 X-treme
                        O/A Torch Setup
                          Even with some guess work you should be able to come close enough to burn it and have it weldable. It would be a big problem if you were to come up an inch off. Heck its so primitive you could hold the thing up there and burn around it till the pipe went thru the hole.
                            You could even burn the hole smaller and take a Crescent type wrench and flare the hole out for a custom fit.
                              If you want to layout, fishmouth a section of 3" cardboard tube or cheap 3" vent pipe and use it to trace over the tank.
                              John
                              John
                              Millermatic DVI
                              Millermatic 375 xtreme
                              And a brand new Syncro 200!!!
