I just got in a Meyers snowplow that needs refaced. As soon as i get the sheet rolled i will put up some pics...Bob
Snowplow reface
That's what I thought. I've never done a snowplow, but I've done several D9 Cat dozers. they are rolled to a smaller radius then tacked on the bottom and run up on something solid and tacked on top befroe welding out.
I was curious to see if the same method was applied to the plow.Jeff
Did it from a flat sheet, rolled it on in place. Look at the last pic, blow some holes in the angles to let the water drain out.
Sberry
nice job.
aametalmaster, how is yours comming along ??thanks for the help
[email protected]
I shouldnt have hijacked Bob's thread. He is or probably will be aware of the drain hole problem, its an easy fix with the skin off.
I will agree about the old Meyers, I got mine for free and thats about what its worth. One major big pain in the azz.
I didnt have the sheet rolled, did it on the frame with a couple clamps.Last edited by Sberry; 07-28-2008, 02:33 PM.
No prob on the hijacking thats how we all learn. I guess .080 ish steel can be bent around pretty easy sure better than 3/16" plate from the old days. This plow is only 2 years old and took a beating last winter plus the salt eating at it. The only thing i did so far is order the steel and price a new cutting edge, his is broke but i would use it like that if it was mine it won't hurt a thing unless it falls apart on a big job so i guess a new one would be a good idea...Bob.Bob Wright
Just cut out a cardboard template to give to the shop doing the forming. A lot of times plows or dozer blades aren't a perfect radius, especially if worn or bent, so a template will get you very close.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by Sberry View PostDid it from a flat sheet, rolled it on in place. Look at the last pic, blow some holes in the angles to let the water drain out.Millermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
No heat, I believe it was 16ga. I used the full sheet to help with muscling it and as I recall had a 4 inch channel or something I clamped along it, I figured out something, as I recall it took an hour or so. If I was going to roll it I would have it slightly undersized so I could spring it back against it, with 16 I could manage , heavier would likely be a problem.
Well its almost done. I just need to bolt the cutting edge on when it comes in. I used 14 ga sheetmetal a 2x4 and a hyd jack with a chain wraped around the plow and the metal jacked down using the chain on top of the jack. 3 jacks would have worked better for re adjustment reasons. My arbor press would have been great to use if i had it welded together. Cost was 64 bucks for the sheetmetal and 120 for the cutting edge with shipping and 10 bucks for the paint...BobBob Wright
Originally posted by aametalmaster View PostWell its almost done. I just need to bolt the cutting edge on when it comes in. I used 14 ga sheetmetal a 2x4 and a hyd jack with a chain wraped around the plow and the metal jacked down using the chain on top of the jack. 3 jacks would have worked better for re adjustment reasons. My arbor press would have been great to use if i had it welded together. Cost was 64 bucks for the sheetmetal and 120 for the cutting edge with shipping and 10 bucks for the paint...BobBB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
