Is there someone that has welded inconel 718? I have never and need advise on what process to use. What rods? etc....
welding inconel 718
We weld aircraft engine parts with Tig and EB. it needs special filler which is pricey. Each flavor 625 / 718 etc needs it's own filler.
Keeping in mind I'm a NC programmer and a welder for fun, I've welded some 625 and it's easy. Nice clean welds. Company scrap bin provided some 625 sheet that I made into the flue flanges for my wood stove, they will NEVERburn out. (And my welds are holding up nicely) The stove parts worked so nicely I'm collecting bits and pieces to make barbarque burners.
Frank
(aka Fred)
MM200 (antique and still cook'n)
Lincoln 160 buzzzzzz box - left to live with a nice youngster
Dynasty 300DX
Spectrum 625
Chevalier Knee Mill - Bridgeport clone you idiot.
Homebuilt tube bender - with home made dies no less
Delta Drill Press & Grinder collection
Needed - a bigger shop to use the stuff
Heres about everything you would want to know. http://www.hightempmetals.com/techda...l718data.php#22- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
Jerm,
Just weld as if you are welding stainless, with the proper filler ofcourse (718) the puddle will be a little different but not alot as compared to stainless, be sure to use some argon behind the weld, if your going to get your weld x-rayed for a cert besure to file the edges to make sure there clean and scrub the rod with alcohol and scotchbrite and wipe with clean cloth.TB302
Dynasty 200dx
Hobart beta-mig 250
Hobart Handler 140
