I just finished typing out a thoughtful and insulting reply, creatively using all eleven smilies when it told me I was limited to four per reply and to go back and fix it. Oh well.
my screen is cut off short also, still dont know why ??? but there is a pull down set of them. the next to the coller change option is the only way i can get them also.
although i have memerized how to make most of them the drop down is the only option i have also. (see pic)
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
my screen is cut off short also, still dont know why ??? but there is a pull down set of them. the next to the color change option is the only way i can get them also.
although i have memorized how to make most of them the drop down is the only option i have also. (see pic)
Fun, a couple things, first of all you always want to make sure you are running your IE browser full screen. See the red X, the box and the dash in the upper right hand corner of the window? Click on the box between the X and the dash, that will make it full screen, and turn the single box into 2 boxes on that button. Also, be sure you are at least running your screen resolution at 800x600, 1024x768 is better if your screen is big enough for the text to still be readable at that resolution.
Between those 2 things, you should be able to see the whole thing, or at least quite a bit more than you're seeing now. Let me know how it worked for you.
thats not it, i am in ,1024X768 and it dose not matter if in in small or large screen mode it cutts off the page and turns the rest black. its just not there ??
not shore why but it just stops the screen after the first row of smillies, see the atached screen shot. its just some thing i have to live with, anoying but thats life with XP i have never been happy with it. the only thing i like is the pic. resizer.
thanks for trying though.
thanks for the help
check this out i tryed resetting it as a left to right to left doc to a left to right doc and it just moved the smilies to the other side and cut them off ??
strange check out the pic.LOL
as you can see the additional options box is the proper size and centerd, just this box is out of wack ?
it might have some thing to do with the way i set my options in the miller controle panel, i'll have to take a look at that but dought i'll be able to figure it out. if i do i'll post it so wireburner can fix his too.
for the most part i just type out the smilies, the ones i use the most i have lerned to type insted of clicking on like : eek : without the spaces is , and : p is and so on
thanks for the help
i still dont have a solution.. i reported the post so maybee the teck. guys/gals can look into it. this is not the first time its come up. i posted a similer post a wile ago but no one came up with a solution. perhaps this time there are enough of us to justify the time to figure it out??
i always wonderd why we were limited to only 4 smileys on this site also. some times ya just need more.
any how, if i get any answers i'll defenetly pass them on.
just so every one in teck. knows i am running windows XP with enternet explorer 7 the latest updates installed.
maybee you guys should also list what you are using so maybee they can find a link.
thanks
James
thanks for the help
