I augmented the standard cart which came with my MM180 to also accommodate my new Spectrum 375 Extreme. It is basically a "side frame" with seperate cable hangars for the welder and the plasma cutter and a shelf of sorts for the plasma cutter. This is just a temporary measure to bring some sanity to my small shop until I have time to build a proper cart for these two excellent machines.
Miller Welding Cart
Miller Welding Cart
Larry
"I feel for the man who can only spell a word one way"......Mark Twain
Lincoln AC225-S (OLD/Copper Wound)
Lincoln Weldpac 100
Miller Matic 180 (auto set)
Miller Spool gun 100
Miller Spectrum 375 Extreme
Victor Super Range IITags: None
Originally posted by fendermender View PostThat is cool.
How do you like the mm180?
Randall
JamesMiller Dynasty 200DX SOLD
WeldTec Water Cooler SOLD
Miller Millermatic 180 w/ Spoolmate 100
20Ton press
And lots of Cut-off and grinding wheels
www.IAGPERFORMANCE.com
Thanks. I could not be happier with the MM 180.
I really did not expect to use the auto set feature all that much. But in practice it is much quicker than refering to a chart or relying on memory for speed and voltage settings. I like it. So far I have had no regrets about my choice of welder or plasma cutter, they are both impresive machines.Larry
Lincoln Weldpac 100
nice mod.
great little cart addition. looks like the shelf is small enough to still alow the door on the MM180 to be opened for wire replacement.
thats a lot of function in a small space with that cart combo, congrats on getting some great equipment.thanks for the help
[email protected]
Originally posted by fun4now View Postgreat little cart addition. looks like the shelf is small enough to still alow the door on the MM180 to be opened for wire replacement.
Thanks. Yes the door will raise fully on the 180 with the plasma cutter in place. Also if you remove the plasma cutter there is a gap to allow clearance to use the handle of the 180 to lift it off of the cart. I will need to add some bracing from side to side on the cart and put some larger wheels on it before I am satisfied with the result.
Larry
Lincoln Weldpac 100
Originally posted by MilwaukeeMike View PostVery Nice, also like the grate over the garbage can
Glad you like it. That pic got in there by accident but the grate over the garbage can makes a decent cutting table for the plasma cutter and prevents a lot of sweeping up....Larry
Lincoln Weldpac 100
Larry
Lincoln Weldpac 100
You prompted me to do same!
I incorporated my old Miller cart into one that I made.
NOTE: I have since expanded the wheelbase as my wheels were to close together for the weight I had.Don
Scottsdale, AZ
www.savagesun4x4.com
MillerMatic 211 AS
Hypertherm PowerMax30
Bernard 300 Amp Q Gun
Bernard 200 Amp Q Gun
Milwaukee Band-saw/stand
10 Angle Grinders 8, 4 1/2" -2, 7"
DeWalt Chop Saw
Craftsman Twin-Blade Saw
12 Ton Shop Press
Optrel Satellite Helmet
Miller Elite Helmet
The wheels I used were the maximum height I could get by with (without a total rediesign). The reason being that my cart is stored under overhanging storage and the way it sits now the flow meter has about 1" clearance when mounted on an 80 cf bottle. If not for that I would probably have used 10 inch wheels on the back with 4" casters on the front.Larry
Lincoln Weldpac 100
SSJ: I wouldn't hang my grinders by the cords, it will break down the stranded copper inside, over time. If the frame cross pieces are angle (pointing up), just rotate your grinders and hang 'em by the guards. Or weld a piece of 1 1/2" strap across the cross pieces so you can. 1" is probably too narrow and will allow the grinders to 'swing in' on their guards. 1 1/2 or 2" will help keep them vertical. It's how they do it at weld class. IMHO and none of my business.RETIRED desk jockey.
Miller Syncrowave 250.
Originally posted by Craig in Denver View PostSSJ: I wouldn't hang my grinders by the cords, it will break down the stranded copper inside, over time. If the frame cross pieces are angle (pointing up), just rotate your grinders and hang 'em by the guards. Or weld a piece of 1 1/2" strap across the cross pieces so you can. 1" is probably too narrow and will allow the grinders to 'swing in' on their guards. 1 1/2 or 2" will help keep them vertical. It's how they do it at weld class. IMHO and none of my business.
But I like your idea better and I plan on either cutting out my center bars or just adding some 'L's to the bars and hang them by the guards. I can assure you its on the LISTof stuff to do
Don
Scottsdale, AZ
MillerMatic 211 AS
DeWalt Chop Saw
12 Ton Shop Press
Miller Elite Helmet
