Anybody have a need for this?
  • Anybody have a need for this?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=008
    I have one like this and It runs my mm175 without even breaking a sweat.
    MM 211 W/ Spoolgun
    Diversion 180
    Spectrum 375 X-TREME
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
    I didn't look it thru completely but Mr handyman there has fooled with the grounding by changing the recept on that unit, buyer beware.
      looks like a nice unit, i could use one of them but i suspect it would end up well out of my $$ range. right now i use a 5,500 for backup power. it gets the job done but dont think it would run my welder's.
      thanks for the help
        Yeah, why not just make a Pig Tail??
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          A 13KW rig should run your whole house without breaking a sweat!
          They come with a 4-wire plug because the ground and neutral are isolated in the newer generators. If he swapped out the 4-wire for a 3-wire, I wonder which leads he hooked up to the receptacle.
          Depending on which way he wired it, and what load he fed with it, there's a possibility of damage.
          Hank
          ...from the Gadget Garage
          Millermatic 210 w/3035, BWE
          Handler 210 w/DP3035
          TA185TSW
            No big deal. If he put the ground wire (green) on the groung lug (green) and capped the neutral it will work fine. If your equipment is 3 wire why screw with a pigtail that can get lost or left behind. Do it right. If you don't know how, hire an electrician.
            Some people are like slinkies. They're not good for anything, but you can't help but smile when our see one falling down the stairs.
              Yes, it would very likely work, just may not be safe. If you were running a single piece of 230 volt equipement that would be true and safe. If you were running a dryer that wouldn't necessarily be safe. Even if the dryer were wired for three wires, still not safe. Electric range, not safe. Feeding multiple 120 volt circuits, not safe. So it really does matter what is being done.
                Whos to say that the seller is not a licenced electrician or power worker?
                  Generator
                  [email protected]!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
                  Millermatic 210
                  Syncrowave 200
                  Spectrum 625 X-treme
                  Hobart Champion 16 W/
                  Miller 8VS Suitcase
                  Miller 3035 Spool Gun
                  Tons of Tools
                  Microwave
                  Laptop and Printer
                  Speakers in the Back for all to hear Sirius Radio!
                    1) Remember that a generator does not have an "earth ground". The "ground" and the neutral ARE THE SAME. Unless you drive a ground rod and connect the neutral there IS NO GROUND. If you think that because you have a 3 wire 120v receptical on your generator and a three three prong plug on your grinder your grinder is safely grounded, you're wrong.
                    2) If your 230v dryer is designed for three wire, why wouldn't it be safe???
                    ...at least as safe as it could be given that a generator HAS NO EARTH GROUND.
                    3) Before you ask, yes, I've been a licensed journeyman commercial and industrial electrician since 1982.
