Leathers
  • Leathers
    I went thru my shop and collected my leathers in to one pile. I have three aprons, but one goes with my blacksmithing, different things in the pockets mainly. I have an upper jacket, a full jacket, sleeves, gauntlets, good gloves and not so good gloves.
    I have the heavy cotton welders shirt, and then several buckets, fixed shade lenses and autoshade, as well as two or three pairs of goggles. Is there any type or needed style that I have mentioned that I should have? I stick weld, plasma cut, MIG weld and TIG weld.
    Jerry
    ok , im confused. what was the question again ??
    thanks for the help
      I cant stand wearing leathers the smell of new leathers makes me sick plus I get too hot in them.
      But your ? makes no sense.
      TJ______________________________________
        i like using a leather aprin when using whire wheels.
        thanks for the help
          The leather apron while using a wire wheel is a good idea. Guess I never think to put it on and then I'm picking wires out.
            Exactly how hot are you in your leathers?
            Nick
            Miller 252 Mig
            Miller Cricket XL
            Millermatic 150 Mig
            Miller Syncrowave 200 Tig
            2-O/A outfits
            Jet Lathe and Mill
            Jet 7x12 horz/vert band saw
            DeWalt Multi Cutter metal saw
            Century 50 Amp Plasma Cutter
            Propane Forge
            60" X 60" router/plasma table
              I only use leathers when I'm doing overhead.
                What do you guys use for arm and body protection while welding?
                Jerry
                  Girl I am so hot I is smoking
                    This afternoon it will be 90 or more, so I won't welding if I need to wear leathers until the sun goes down. Even then it will be too hot, but bearable.
                    I wear leathers and the heavy cotton shirt, so I won't get burned or worse get RF burns from the electric welders.
                    Jerry
                      generaly just a shirt and gloves, but if im doing inverted or over head work i go with my welding jacket with the metal sleves. the leather was first gotten for plasma cutting and then later when i got whire wheels it and a full face shield were a every time no exceptions thing.
                      thanks for the help
                        Pigskin Baby
                        I would try pigskin, it is light weight, abrasion resistant and much cooler than leather.
                        Steve Beckman
                        Rockford Industrial Welding Supply, Inc.
                        "Setting the Standard in Service"
                        1.800.226.1904
                        riws.com
                          I wear a long sleeved school uniform when I'm welding normaly.
                            Fun4Now, it must be warm under there, but that is the way I dress up to weld. My sleeves are pigskin, they work o.k.
                            Jerry
                              naa NY a few months ago just as spring was getting started, so the jacket was a good thing. but i still would have ben in it if it had not been cool out. 2 wire cup brushes and 2 flap disks and 2 welders all going under 1 car at the same time. it was a good thing.
                              thanks for the help
