ON to the Next Project...
You fellows have been great with your comments. I'm on to another project, 20ft long by 3ft. deep shelving built like those at Home Depot and Lowes.... The shelving arms are held in place with 1" diameter steel pins, so when I don't need the shelving, they can be "UNPLUGGED" and taken down for more flexible use of the space...
I'm mounting the arms, not welding them, to the wall framework. The vertical members are welded to weldplates tied into the rebar and slab's deep and wide footing. The wall framework is 3X3" and 4X4" steel tubing reinforced with rebar and each is filled with concrete to not only support the outside wall, but take the heavy side loading of the stacks of dense hardwood lumber. Welding sure helps me keep the cost down and therefore, lets me have things I could never afford to have done....
Bill
Bill
