how to bend conduct without a bender????
  • MAC702
    You didn't tell us what size and wall-thickness of conduit you want to bend.
  • wireburner
    I try and post some pics during building it ,belive I will use the torch 4 this job
    Thank Y`all alot !!!
  • Goodhand
    I've had good results in bending EMT up to 2.5 inches OD by packing sand inside and capping the ends, then heating with an O/A torch and tweaking. In fact the bending went so well, I had to reheat and straighten a bit.
  • Fat-Fab.com
    The sand idea works great I use sand box sand from the local HIC
    you want the finest (smallest) grains you can get filler up don't pack it then bend a way you need to leave some room for the sand to move while bending
    TJ
  • weld_13
    ive heard of the sand idea and u can tack some rebar or something on to sheet metal in a curved line shape and heat it as u bend it
  • fun4now
    i have herd filling the tube with sand helps keep it from colapsing when bending but never tryed it.
    be shore to post pic's as the build progreses.
  • wireburner
    started a topic how to bend conduct without a bender????
    I need to know how to bend some conduct with no beder,I am building a mini-tricylce (modfing mini-chopper plans) using bicycle parts ,chain, pedals most of the stuff you would find on a bicylce
    the reason I`am building it so i can get pratice for building a mini-chopper with a motor
    I`am going to build a fake tank (using english wheel)
