Air hose H E L *
  • Air hose H E L *
    Hey All,
    I HATE airhose. Its got to be the most uncooperative material anywhere with garden hose a close second...
    Is there any hose out there that: doesnt kink, coil up(in the wrong direction of course), or that will lay out nicely and can be coiled up easily.
    I just bought a 75 ft. hose and its got to be the most dificult piece of equiment in the shop. Ive given up trying to unfurl it nicely and have just left it to lay in a heap on the floor... I dont have spools to mount it on (yet) so this is another issue. Any of you guys (and gals) built spools to store your air hose? got any pics of the same? Thanks . any * E L P is appreciated.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    I love that 1/4" polyethylene "contractors" hose. Flexible even in cold weather. Plenty of air flow for all but the biggest air tools. I use it nearly all the time.
    When I need it, I have a couple hundred feet of the unmanagable stuff you refer to, but I tend to leave it hanging on its hook unless I need air a long way from the compressor.
    Hank
    ...from the Gadget Garage
    Millermatic 210 w/3035, BWE
    Handler 210 w/DP3035
    TA185TSW
      HD had a decent retractable reel for $50 close out, I am sure they are replacing it with something inferior. It was a 50' reel. I have gown weary of my manual reel, though it will hold 125'. I would like to put two retractable reels on the ceiling in the shop.
        There is a world of difference between air hose and air hose on a reel. Night and day.
        The only hose that's not bad to work with is that flexible stuff mentioned above. Ridgid sells a 50'er at home depot.
        EDIT: Even manual reels are better than no reels. Although I have never used one longer than 50'.
        Miller Maxstar 200 DX
        Miller Syncrowave 180 SD
        Hitachi 4.5" grinder
        http://mhayesdesign.com
          Hose reel. I have 2 of them in my small shop. One overhead next to the lift and one big one next to the door so I can use it in the shop or in the paved area in front of the shop.
          If you don't have one yet do not coil the hose in circles. Each coil adds a twist that has to be taken back out or it will try and kink the hose. Rather than coiling in circles lay it on a figure 8. Each loop of a figure eight counteracts the twist of the last one. Always coil the hose by pulling it back to the storage point and not winding it up as you walk back and then drop it. Stand next to the storage point as you pulll and coil it and keep the end from getting under any coils when you are done. This radial twists out and keeps the end from getting under a loop making a knot the next time you pull it out. you can lay a figure 8 and then pick it up and hang it on a hanger and it will still unfurl neatly. for many years I kept an hose on a 2X4 nailed to a stud.
          Weekend wannab racer with some welders.
            never really had a problem, i use only rubber air hose, the PVC stuff sucks. I have a harbor freight hand crank real that costs 20 bucks, it doesn't leak and has 50' on it. I also nevr go longer than 50 on any single hose, they are easier to manage that way. I agree with pulling the hose toward you while rolling it up instead of walking along it. If you pull it it gets a chance to untwist.
            Millermatic 175
            Spectrum 375
            All kinds of Smith OA gear
              The 1/4" poly hose is great. A lot of the guys refer to it as snakeskin because of the cross hatch fiber strands that you can see in the translucent material.
              I agree 100% about the figure 8 wrap. Its how we coil all our underwater umbilical lines so that they feed freely and don't twist or kink. Kinks are bad for the diver. they are a bit unwieldy to move around though. Seems to work best on a fixed position like a hanger.
              I have also used a basic 5 gal bucket. Drill a hole big enough to push the end thru neer the bottom leave about 3' sticking out or enough to hook up to the wall connection. Then coil the hose in the bucket. You can then just pull out what you need. It does tend to twist a bit though. If you put a weight in the bottom you can pull out more from across the shop with out tipping the bucket over. The added weight is a pain if you need to carry it arround though. I use this with extension cords also.
                I have two of the $10 HF manual reels. They state 100', but I have 125' on each one. Other than that, I've used those nice poly ones before and would definitely be the way to go next time.
                  Speaking of Harbour Freight, they sell Genuine 50 Ft. Goodyear Rubber Air Hose. Every now and then they go on special. Best air hose I have ever used. Also, its the only good rubber product Goodyear makes, I don't like nor will own anymore of their tires. Never wore one out, they blew out first.
                  Charlie
                  '77 Miller Bluestar 2E on current service truck
                  '99 Miller Bobcat 225NT for New Service Truck
                  '85 Millermatic 200 in Shop
                  '72 Marquete 295 AC cracker box in Shop
                  '07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
                  Miller Elite and Digital Elite Hoods
                    Dude,,,,,,,,
                    Relax.
                    Be more at one with nature, and the hose.
                    Rather than fight it, or look for hose reels,
                    You might just need to find a monk you can learn from.
                    I'm not real sure where to get it,
                    but you might need to find some of that 'Zen' stuff
                    we heard about as kids.........
                    "Gone are the days of wooden ships, and Iron men.
                    I doubt we'll see either of their likes again".
                    Circa 1920.
                    Author:
                    Unknown US Coast Guard unit Commander.
                      Originally posted by flukecej View Post
                      Speaking of Harbour Freight, they sell Genuine 50 Ft. Goodyear Rubber Air Hose. ...
                      I meant to add that, too. It was a great deal, and one of the things I remember when people tell me that HF is nothing more than cheap Chinese crap.
                        I use the Goodyear hose and it's great. The other brands are like fighting a
                        slinky when it's below 60*
                        Nick
                        Miller 252 Mig
                        Miller Cricket XL
                        Millermatic 150 Mig
                        Miller Syncrowave 200 Tig
                        2-O/A outfits
                        Jet Lathe and Mill
                        Jet 7x12 horz/vert band saw
                        DeWalt Multi Cutter metal saw
                        Century 50 Amp Plasma Cutter
                        Propane Forge
                        60" X 60" router/plasma table
                          Nothing like rolling 50 foot of hose on a hanger at waist level. So many loops. So I moved our hangers to arms reach up. 4 wraps gets rid of the 50 foot hose and those pesky extension cords also. I figure 8 the 50 foot acet hoses on the cart.
                            Air hose...
                            I have used them all. My favorite is the non-maring type Made by Senco. It uses barbed push in connectors. The 1/4" is the lightweight champ for nail guns and staplers, The 1/2" when you need more volume. Light weight, strong, smooth surface stays relatively clean, and coils easily. Does not get super stiff when cold either.
                            John
                            John
                            Thunderbolt AC/DC
                            MM 175
                            Maxstar 150 STL
                            Blue Star 185 DX
                            Spectrum 375
                              I have several reels. The one in the second pic is kind of hard to beat at Walmart for 50$ hose and all.
