whats the best
thats a question without an aswer. are you talking about wich welder is the best MIG or wich is best MIG TIG or stick?? and to do what?? they all have there uses and to say one is better than the other you need to know what you intend to use it for. you have not given enough info to even begin to get an aswer.
if you are asking about wich brand... well thats easy MILLERthanks for the help
[email protected]
it realy comes down to what you are welding and how fast you need to do it. with a good AC/DC tig you can weld anything within its amp rateings. mig is king for blasting out metal fab but you need a special feeded like a push pull or spool gun for aluminum and some SS will need puls, but MIG is much faster than TIG. in most general fab shops the MIG will get the bulk of the work but in other more specilized shops , like boldfabrication's TIG is king.
so your question is still unanswerable.
TIG is the most versital but not always the best choice for the job.
O/A is realy the all out most useable as it not only dose what the TIG can but also cuts. but again not easy to lern like TIG its hard to master, MIG can be done well in a shoret pereiod of time with proper teaching where TIG and O/A will take a biyt more to get good at and even longer to get good and prity at and most likely never be truly masterd.thanks for the help
[email protected]
yeh the a/o does pretty well as long as uve got a beefy enuff torch but i still have some mastering to do on a/o. like what u brought up a/o cutts and arc does to but what i like about the arc is all u have to do is crank up the amps and cutwelding...its awsome
Depends on application
Hmmm, if going for versatility id have to say the OA setup
If welding stainless TIG
If general cob job on carbon steel MIG
4130 tubing OA
Cast Iron OA
Aluminum >.125 TIG
Aluminum < .125 OA
Heavy Steel Work Stick
Brazing, Soldering OA
Each has its home, I wouldnt try gas welding 1" plate, or using a mig welder on my 1932 great lakes nose bowl.
-Aaron"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
I'd say a good multi-process machine.Oh and my choice would be blue baby
Multi-process because you never know when it will (and it will)come in handyIf I'm strapped for cash a nice little mig(0.23-0.35) WOULD STILL TRY AND GO BLUE but red will be okay
till have enough to go BLUE
Originally posted by weldone View PostI'd say a good multi-process machine.Oh and my choice would be blue baby
Overall fab, I go with my MM251. I plan to get more into aluminum, so I'll go with TIG with my Dyn200 (once I buy the contractor's kit). For thicker aluminum, plan on using the mig/spoolgun. MIG is so much faster for steel, but at work we use all stick...O/A at work to cut steel, home is my plasma Hypertherm G3 1000
I'm not late...
I'm just on Hawaiian Time
thats a purty good plan if ya ask me. MM251 W/Spool gun, Dyn200, and hyp. 1000 should take care of just about anything to wander in the front door.
i just have to upgrade my plasma and MIG and i'll be good to go......well i supose a buisness with a door would be a good idea too.
ruff fab in a shop will most likely be done in MIG, as its fast. the XMT is a great option for versitility but it also has a few drawbacks. its verry expensive to outfit it to do several things, if it brakes one welder takes out your ability to MIG, TIG, and stick all in one quick burnt circuit board. it is also limited to DC TIG only, no AC on the XMT's.
if its about getting the most options out of one thing at the least expense, O/A has got to be the one to go with. cut any metal, weld any metal, and heat for bending or altering the metals structure, ie. making it strong and brital or weak and bendable, relieveing stress. but again it takes some real time to lern to do all the above with an O/A setup. however the hole thing can be in the shop for under $400.00 and thats with good quality equipment not the cheepo stuff off the flea-pay market.
dont be suckerd into the great $69 deals on flea-pay, spend the $$get a good setup like a Victor or Smith and you will have it for a life time. trust me i know i picked up a flea-pay special. all i can say is im lucky to still be alive to tell you not to do the same. there flash-backs dont work at all. i had one flash back all the way into my reg.and never knew it till i went to hit the cut handle and got nothing ??? shut it down realized the torch was hot as all heck. opened it up to a burnt out shell with melted o-rings. and it didnt stop there. pulled off the torch at the hose conections, yep blackend there too, pulled the hose at the acet. reg.........WOW!!! black all the way into the reg. needless to say i didnt get another one. i now have a small Victor. its a nicer size and works 1,000% better and no flashback problems. it also has quality flash-backs built in. i would also recomend a good set of add on's as well. there are 2 types, getting both would be best but be shore to get atleast a torch with built in flashbacks or add them, did i mention quality here would be good.
thanks for the help
[email protected]
Originally posted by wireburner View PostI perfer Blue migs ,although i got a red 1 , Red sticks, blue tigs, but ain`t never used a Esab
I like the Esab 260 multimaster. For about 2500 bucks you can get one. It does tig dc, also.
Comes with dual cylinder rack, 4 roll drive system, 15 foot mig gun, ground clamp and cable, stick electrode holder and dinse connector, regulator.flowmeter and hose, 10 lb. sample spool of .035 wire and 5 lb sample of stick electrode. Drive rolls for .035-.045 wire.
Then add Arc control optional Module - $47.75, if you don't like the Miller 251's soft arc.
Add the Output Control Front Panel Optional Remote Module - $54.80.
Add the spoolgun Optional Module - $89.30 and your set.
The fact that dual tank running gear, being standard pays for all these options is something to think about.
If you want pulse you can add that module later.
I don't think anyone can say that it isn't well built.
P.S.______I KNOW, it's made in Sweden. Lets don't start.
r90sLast edited by r90s; 07-19-2007, 02:25 PM.Careful with That Axe, Eugene
