drier for air compressor
  • drier for air compressor
    who makes a good drier for my air compressor? I have a Motorgard filter on the plasma but need something on the compressor itself that has a dissecant in it.
    thanks
    littleboss
    porter cable makes a good drier / lubricator or just a drier the same with cambell/hossfield
    miller bobcat 250
    wc 115a
    spoolmatic 30a
    centery 250 mic
    2 lincoln 225 stick
    a 1954 hobart portable welder w/ willies jeep engine
      I use this one: http://www.pricegrabber.com/search_g...sterid=5432441
      Some other good ones here: http://www.airdryers.com/prod.htm
        If you have a truck junkyard in your area you can put a truck air dryer on it . They are made for lots of air volume and have dessicent cartriges in them.
          Thanks.
          I found a Campbell Hasfield at Amazon.com
            Water fights
            Boy do we need an air drier at work. If the compressor has been running for a few minutes and no a lot of air is being used you can take an air blower and shoot a stream of water clear across the shop! We even showed our foreman the other day.
            Dynasty 200DX, first generation
            Makita 5" grinder
            Makita 14" abrasive saw
            IR SS5L compressor
            Whole bunch of hand/air tools.
            and a wish list a mile long
              just a thought, i run a basic velocity change drier with a filter element for general use and then have a refrigerant based drier for the more critical processes that I turn on when needed. I couldn't complain, gave $20 for the drier at an auction and all it needed was a new power cord.
              SSS
              Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
              1 Thessalonians 4:11-12
                thats a sign to drain the tank.
                welding...its awsome
