You do that scroll work yourself? or did you get it from Kings???
AWSOME WORK!!!!!!!!!!!!
oh, and how did you "plant" those feet in the resturaunt? I didn't see any lag bolts???
a defined area on which armorial bearings are displayed and which usually consists of a shield; a protective or ornamental plate or flange (as around a keyhole); the part of a ship's stern on which the name is displayed… See the full definition
Ed Conley http://www.screamingbroccoli.net/
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
I see you've got quite the anvil collection. Nice. I'm not much of an anvil guy, but I am a certifiable tool junkie... which can be a good thing and a bad thing. Mostly a good thing. I think most here would agree.
Hi Bert,
We laid out the uprights for the railing on the slab before the tile went in.
If I remember correctly, the uprights on the railing were 3/8 x 2 flat bar.
We probably had the holes cored to 3" diameter so we can just pour the railing in place. This is a clean way to do it, you just have to make sure nobody monkeys with it while it's setting, as you're provisions for levelling are literally "set in stone." The escutcheons- excuse me, ornamental cover plates- were also from 3/8" material, slotted to fit over the 3/8" x 2 balusters. So... no bolts.
When you do thing this way, there's always that nagging feeling of "I sure hope I welded this thing together correctly to fit the cored hole pattern..."
Usually it works out.... usually.
Measure twice. Don't lose your measurements. I'm horrible and often find key measurements on the side of a cardboard box, napkin, back of my hand. Yikes.
Thanks for the interest.
Chris, ok...before the railing is set in "stone", do you put the escutcheons in, then set the railing in the hole? then you tile over, then the escutcheons are what...epoxied down onto the tile?
Sorry for being a dummy about this. Never seen it done before..also, the scrollwork? custom made? or bought?
thanks Chris!!!!!!!!!!
Escutcheons are slipped on the railing before it is set. They can be glued down if you like. Tile went in before railing. They left our holes open for us.
Scroll work was cut with a water jet to my design. We had lots of time on the machine and it was not cheap.
The pattern on the fixture was cut in .050 aluminum. There were 4 sheets of 4' x 10'.
The railing was cut from 3/8" mild steel.
I out-source this cutting and when they hit me with the bill, it hit HARD.
