I just recently switched to sub arc welding. I weld ink rolls for printing machines to restore diameter lost to machining. Anyway, re-using the flux seems to be somewhat of an issue. While I'm getting good performance overall, once in awhile I get a piece of garbage stuck in the nozzle, exposing the arc, adding porosity and headaches. I sift it through a screen with an air vibrator. I originally tried door/window screen and found it to be a bit small and I was throwing good flux away, Currently I'm using screen with about 1/8" square openings. I put 2 layers down and of course they separate allowing some smaller, yet too big to use particles of slag through. Any ideas on where I can find some mesh more suited to my needs? I hear there are shakers available, but
the company I work for will most likely not buy it. Any input would be appreciated.
Pete
Pete
