New Welding Talbe... Finished!
  • New Welding Talbe... Finished!
    Ok. You remember this one:
    Well here is the final result (minus paint or something to protect it from the weather):
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    the pics are not showing up
    EDIT:
    ok thanks for fixing them.
      I'd though I'd also post a little how-to as well. I've gotten really good at welding these steel sq. tubing cages for tables and other things.
      First of all I wanted to show these off. These aluminum corner jigs have been soo good to me. They were only $50 ea. (from Walker Industries) I have four of 'em and they make putting these tables together possible without having a flat surface to clamp to.
      So first I cut all the metal so I can make the top and bottom as mitered rectangles with at least one cross bar and (in this case) six uprights. I assemble the mitered boxes first. I clamp all four corners into the jigs before I start welding. If I can't do all four at once (sometimes the shorter dimension won't allow me to get two of the jigs next to eachother), I'll do two, tack weld and then do the other two.
      I tack weld everything first. Two tacks on each side of the tubing. I tack the entire cage before I start any major welding.
      Once the top and bottom are done, I'll tack the upright to one side and then put the other side on and tack that. I find often when I do this, I need I tie-down strap to force the metal into place before I clamp and weld it.
        Once the entire cage is tack welded together, then I decide where to weld. I learned after the first table that I did: if you weld everywhere the table gets warped like crazy so I always weld selectively. I weld in places that provide vertical strength, but don't cause to table to warp in such away that we bring it out of level. On the top and bottom, I only weld the vertical welds and I weld all the welds on the outside of the table.
          Then I welded the plates on for the casters. This turned out the be a disaster. One the second tap, I broke the tap off (which no surprise since I was going through 3/8" of steel), so I decided to weld studs into the holes. This didn't work particularly well either, as the welds around the studs prevent the caster plates from sitting flat so I had to weld on some 1 x 1/8" flat bar for the caster to sit on.
          Finall I welded the angle iron onto the ibeams. When I put them onto the table, I was surprised how nicely the slid up and down the length of the table. There's about 1/8" of play on either side.
            That's pretty cool. It's like a double saw horse that doesn't require level footing.
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Thermal Dynamics Cutmaster 81
            Smith O/A rig
              Exactly, since I definitely don't have any of that in my back yard!
                W beam makes great clamping stock. I think you're gonna like that rig.
                Syncrowave 250DX
                Invison 354MP
                XR Control and 30A
                Airco MED20 feeder
                Smith O/A rig
                  Hope that 1/8" play won't make it too sloppy, that it could cause something to bend or warp.
                  You might need to get larger pneumatic tires, those small ones on that grass/dirt can be a killer!!!!!!!!
                  I'm not late...
                  I'm just on Hawaiian Time
                    Oh yeah, thanks for the pics and report! AWSOME!!!
                    (glad you showed it BEFORE the paint job!!!
                    I'm not late...
                      Good job,and well detailed.
                      2- XMT's 350 cc/cv
                      1- Blue star 185
                      1- BOBCAT 250
                      1- TRAILBLAZER 302
                      1- MILLER DVI
                      2- PASSPORT PLUS
                      1- DYNASTY 200 DX
                      1- DYNASTY 280 DX
                      1- MAXSTAR 150 STL
                      1- HF-251 BOX
                      1- S-74D
                      1- S-75DXA
                      2- 12-RC SUITCASES
                      1- 8-VS SUITCASE
                      2- 30 A SPOOLGUNS
                        Don't you just love those aluminum jigs!!!
                        At the machine shop I use to work at I was tasked with building fixture bases and new machine bases from time to time. Well with no large flat surface to weld on other then the floor. Those jigs saved the day. I could weld up a table 5x10 and it would be within a 1/16" of being square and plumb. They are worth the price
                        South bend lathe 10LX40
                        K.O. Lee surface grinder 6X18
                        Auto shades are for rookies
                        www.KLStottlemyer.com
                          source of clamps
                          do you have a website for those corner clamps? I've tried googleing it and can't find them.
                          Welders do it hotter!!
                          www.Munsonworks.com
                            I guess they haven't come into the computer age.
                            I got mine at my LWS Sim's Welding Supply: http://www.simswelding.com/
                            They are Walker Industries LF-2
                              If I am clamping to the I-beam, I plan to clamp the I-beam to the table.
                              Sooner than later I am hoping to have a concrete pad to work on.
