I use an old makita 7.25" circular saw and "bullet" carbide blades, works great and the blades are $12.
The blades are rated to .25" but I ripped around 10 feet of .375 plate before the blade started dull up, Definately want ear and eye protection though.
Gets pretty loud!
Also have the evolution 14" drycut saw, runs at 1500 rpm. I bought a couple replacement blades from evolution at $100 each but they didnt last all that long. Then I found out about Bullet Industries, they are selling 14" dry cut blades for $40! The blades are rated at 4400rpm and im running them at 1500 and so far they have out lasted evo tenfold.
Shipped to canada in 5 days also.
Just thought I would throw that out there
Cool tools Rule!
New Toy
Originally posted by Anti-GMAW View PostAbout how long do they last?
Originally posted by Vicegrip View PostYou can tape or clamp a strip of Formica to any metals being cut that you don’t want to be damaged. Chips will get in between the base plate and metal and trash the finish even on plastic covered metals.
Spray gluing butcher paper down makes for a pretty good level of protection and the paper and glue comes off easily with paint thinner.
Originally posted by ace4059 View PostI used one of those to cut AL and I was disapointed. It sucked because the main part the saw slides on across the metal kept digging in and would not slide across it smoothly.
I did try it on MS and it worked very well.Attached Files
You can tape or clamp a strip of Formica to any metals being cut that you don’t want to be damaged. Chips will get in between the base plate and metal and trash the finish even on plastic covered metals. Formica is nice and slippery and the saw will glide. Formica makes a good "folding" straight edge too. You can roll it up a 120 inch long 6 inch wide strip and tape it into a 2 foot loop. If you want to use it as a saw guide you need to add a thin strip of alauminioum angle to your saw base plate and let the Formica ride over the foot and run on the vertical leg. Two threaded holes to mount the angle is all you need. One strip under the saw, one as a guide and roll them both up together when done.Last edited by Vicegrip; 04-03-2008, 05:45 AM.
The milwaukee's baseplate is stainless and very smooth.
I haven't used it on AL yet though.
New Toy
Is that a pipe track or cutting guide in your first picture? If so, do you have more pics and detail? Otherwise, does anyone have a cutting guide for extra-long cuts (other than just clamping a piece of angle or channel)?
I got a Milwaukee 8" about 2 years ago and love it! It's great for cutting bar grate as well.
I have had a couple of 8" blades sharpened, but I don't think it's worth it.
Originally posted by burninbriar View PostMy blades are around 40 or 50 bucks, can't remember exactly. I had Lenox and now I have the Morse Metal Devil and all three have warning not to have them resharpened. That could be because they would rather sell a new blade or liability concerns. I resharpened the Lenox myself on a 8" grinder and it did pretty good. I only used it to get me through until my new blades arrived though.
Originally posted by fabricator View Posthow much are the blades and can they be sent off to re-sharpen?
Originally posted by kcstott View PostWe use to use a Skill worm drive saw and carbide pirana blade like 27 teeth or something a can of WD 40 some hearing protection and cut aluminum plate with it like 1 1/2" plate.
Don't under estimate the power of a good saw and a properly designed blade.
Kerry
Kerry
I was worried about kickback also. The blade cuts in a fwd/up motion and it never jumped once. Definitely don't want to try it single-handed though. It's heavier than a regular saw. It also collects a lot of shavings in a removable side compt. Adam
I have been skeptical of these since I first saw one four years ago. What a nasty mess it could be if it fed back...? Or maybe I'm just being too paranoid?
I got the milwaukee 8" dry cut. It was $289 a couple years ago.
The thickest I've cut is 1" and it goes a little slow on that, but anything under 5/8" is like cutting plywood.
