New Toy
    Originally posted by ace4059 View Post
    I used one of those to cut AL and I was disapointed. It sucked because the main part the saw slides on across the metal kept digging in and would not slide across it smoothly.
    I did try it on MS and it worked very well.
    We put down masking tape on the aluminum sheet we cut with it. Made it slide better and didnt scar up the aluminum. So far it works great.
    Scott
    HMW [Heavy Metal welding]
      Originally posted by Anti-GMAW View Post
      About how long do they last?
      It really depends on how you use or abuse it. I don't use mine enough to give a good answer but I think its fair to say that the life is short if you compair it to cutting wood with a circular saw. A cold cut cut off saw might be a good comparison but you don't have the lack of control damaging the blade like you do with a hand held circular saw.
      Originally posted by Vicegrip View Post
      You can tape or clamp a strip of Formica to any metals being cut that you don’t want to be damaged. Chips will get in between the base plate and metal and trash the finish even on plastic covered metals.
      I have found that using something like you mention,(I never used formica though) I get a lot of chip buildup between the material being cut and the covering. Even when I spray glue patterns down I will get chips stuck between the pattern ant the metal, especially when using a jig saw.
      Spray gluing butcher paper down makes for a pretty good level of protection and the paper and glue comes off easily with paint thinner.
      My sincere thanks , Pete.
      Pureox OA
      Westinghouse 300 amp AC stick
      Miller Syncrowave 250
      Hexacon 250 watt solder iron
        I use an old makita 7.25" circular saw and "bullet" carbide blades, works great and the blades are $12.
        The blades are rated to .25" but I ripped around 10 feet of .375 plate before the blade started dull up, Definately want ear and eye protection though.
        Gets pretty loud!
        Also have the evolution 14" drycut saw, runs at 1500 rpm. I bought a couple replacement blades from evolution at $100 each but they didnt last all that long. Then I found out about Bullet Industries, they are selling 14" dry cut blades for $40! The blades are rated at 4400rpm and im running them at 1500 and so far they have out lasted evo tenfold.
        Shipped to canada in 5 days also.
        http://www.bulletindustries.com/carb...etal%20blades/
        Just thought I would throw that out there
        Cool tools Rule!
