I have had some experience with MIG and OXY but would like to try TIG welding. I am a hobby welder and would like to find a used machine. So far no luck. Are they that hard to find ? Any suggestions? Thanks.
TIG Weling Machines
I would look into a maxstar 150STH complete kit is about 1400+-. I own a Dynasty 200DX and if aluminum is in the picture then it is my first choice but it is overtwice as much. Sources I recommend are www.brwelder.com and www.cyberweld.com
Happy hunting,
Good GTAW machines really hold their value. Those that get deals on used are few and far between and it's usually a family member or friend that gives them the great deal. Usually the better used machines are within a few dollars of new, sometimes on Ebay I've seen used machines go for more than the discount prices from the sources that pjseaman listed.
Decide on your budget and then get the best you can afford. The Maxstars are really great machines if you don't need to do aluminum.
Good Luck on your decision!Bob Sigmon
___________________
Dynasty 200DX w/ Coolmate 3
Miller Passport
LMSW-52T Spot Welder
A/O Setup with Meco Midget
Miller Big Window Elite
Quincy QT-5HD
Having owned two Maxstar tig welders I concur with the other comments. If you are doing MS of SS they really are hard to beat. If you need/want to do aluminum then you will need to spend more money, and there are several AC/DC tig welders to chose from.Regards, George
Originally posted by Bob SigmonGood GTAW machines really hold their value. Those that get deals on used are few and far between and it's usually a family member or friend that gives them the great deal. Usually the better used machines are within a few dollars of new, sometimes on Ebay I've seen used machines go for more than the discount prices from the sources that pjseaman listed.
Good Luck on your decision!To all who contribute to this board.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
