Some of my welds are shiny when some have a dull cast to them. Both welds look good. It seems like the weld I ran a little hotter and faster was shiny compared to a slower travel and lower heat. Welds are the same size. Is one weld better than the other? Tigging on aluminum. Amps, gas flow, are identical. Only difference was the foot pedal and speed.
Aluminum welds
Aluminum welds
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
Originally posted by Bert View PostI was told/taught if your weld is too hot (foot down too hard or too slow a speed), it'll look hazy. Want a shiny weld? Control the right heat more.
FusionKing: any advice?miller 330 abp
everlast 225lx
airco 250a tig
hobart handler 125 mig
o/a torches
Originally posted by monte55 View PostSome of my welds are shiny when some have a dull cast to them. Both welds look good. It seems like the weld I ran a little hotter and faster was shiny compared to a slower travel and lower heat. Welds are the same size. Is one weld better than the other? Tigging on aluminum. Amps, gas flow, are identical. Only difference was the foot pedal and speed.Originally posted by Bert View PostI was told/taught if your weld is too hot (foot down too hard or too slow a speed), it'll look hazy. Want a shiny weld? Control the right heat more.
I usually weld a little slow anyhow unless it's getting pretty close to lunch or dinner time
Hotter and faster and rythym make the best looking beads IMO and the HAZ would be smaller also.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Fusion King,
You got it. Run hot and run fast. No metalurgist, but suspect that it has something to do with prolonged heat changing the molecular structure of the aluminum.
I'm not in their league, but the best anodized aluminum tig welders (tower builders) I've worked with are running at about 195A without a foot or finger amp control. Just a simple on/off switch on the torch. High amps breaks up the anodizing, creates a great bead, and limits the heat transfer. With towers, the welds are painted after welding for protection but the weld bead is shiny. The paint, as I said, is only to prevent oxidation since it's physically impossible to reanodize an entire tower. Some tower builders use 4043 but the better ones use 5356 even though it will not be reanodized.
I've actually found, in most cases, that the Sync 250 is a little more forgiving of technique than the Dynasty's. Maybe it's just me. Good friend of mine (one of those experts) used to use a 250 and now has the Dynasty 300. Says he'd never go back. Guess I haven't used an inverter enough to fully take advantage of the freq. adjustments.
Hope this helps.
PS There was an excellent article written several years ago which circulated around the boards a few months back. In that article they interviewed several of the guys from Pipewelders (Fl Towerbuilders) who developed the bump techinique for welding anodized aluminum. (I posted a link at that time--do a search for anodized aluminum). The son of the owner of Pipewelders, Edison Irving, is a close friend of mine and taught me a lot about the technique.
KP and Engloid are the two tiggers on the board who I have been most impressed with. Both their welding and understanding of why certain things happen in the bead. ASKANDY is probably there too, but I haven't seen as much of his work. If any of those three make a comment regarding tig, you can take it as gospel.
Fusion King: Check out this link [url]http://archive.metalformingmagazine.com/1999/11/miller.pdfLast edited by SundownIII; 03-16-2008, 01:00 AM.Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
One of the questions I had was...........is the shiny bead better than the dull
bead other than looks. Is one stronger, less brittle, etc.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
Originally posted by monte55 View PostOne of the questions I had was...........is the shiny bead better than the dull
I would go as far as to say that the PART with the shiney welds is a stronger PART because you kept more of the original temper...and that depends on the application.
Try not to think so much... OK
Miller WC-115-A
Miller Spectrum 300
Originally posted by mikesparks View Posti can get a shiny weld slow or fast. even if i use my foot to pusle weld it still turnes out shiny
What machine, make-model; x-former or inverter?
And what filler; 4043, 5356; 1/16, 3/32?
Something works for you and WE want to know what it is!RETIRED desk jockey.
Miller Syncrowave 250.
Originally posted by FusionKing View PostI would go as far as to say that the PART with the shiney welds is a stronger PART because you kept more of the original temper...and that depends on the application.
[QUOTE=Craig in Denver;143098]OK, Mike; ya don't get off that easy.
I think he has a Syncrowave 200. I agree with you, I think it would help to turn his balance down to about 4 . It looks like there is still some contamination from the black flakes and the looks of the weld. I sent him a PM if he keeps having problems. He is about 25 miles from me.
Fusion King kinda hit the nail on the head.
If one would study aluminum tower failures, you'd find that the greatest amount of failures occur not in the weld itself, but in the base material adjacent to the weld.
Stands to reason that the less you change the composition of the base metal, the stronger the part will be. Back to the old run hot, run fast suggestion.Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
[QUOTE=bvweld;143104]Originally posted by Craig in Denver View PostOK, Mike; ya don't get off that easy.
And what filler; 4043, 5356; 1/16, 3/32?Originally posted by bvweld View PostI think he has a Syncrowave 200. I agree with you, I think it would help to turn his balance down to about 4 . It looks like there is still some contamination from the black flakes and the looks of the weld. I sent him a PM if he keeps having problems. He is about 25 miles from me.
I was refering to post #3, where mikesparks said he always gets a shinny weld.
FWIW: The reason your guote of me didn't work, you forgot the {/quote] before your comment.RETIRED desk jockey.
Something works for you and WE want to know what it is!THAT'S RIGHT!!!!!!!!!!!! SPILL THE BEANS, BUDDY!!!!!!!!!
If it is only a dull surface appearance it isn't considered a weld defect. Problem is, how do you know it's only surface and didn't penetrate deeper?I'm not late...
I'm just on Hawaiian Time
