I have been grinding my tungstens on a 6 in grinder by hand and I suck at it. No matter how steady I try to do it, it is still not even. Some have said to put it in a drill, which I have tried, but if the drill turns any speed at all, the point will be ground in a spiral fashion which I don't think will be good.
I have a magnetic torch holder in the project gallery, made from a magnetic base indicator holder, which I used a piece of 3/8 round steel and formed it to make a torch holder. This gives infinite adjustments.
I took the same base which will capture a 3/8 piece of round stock. I center drilled the 3/8 stock with the tungsten size I want to sharpen. In my case, I made a 1/16 in and 3/32 in x 3/4 in long dies which fit right into the tool holder adjustment jig.
I also found a rubber plug which I drilled just close enough to hold the tungsten but still be able to slip for adjustment. This serves two purposes;
As a depth stop and something to grip while turning the tungsten during sharpening.
If you have your grinder on a metal table, this works great because of the magnetic base.
With your grinder at its position, it is very easy to move the magnetic base to the exact angle and pitch you select for your tungsten tip angles.
I hope the pictures will better explain what I am trying to say.
