I am building a 12' twin sponson boat and here is the 1st of two of the sponsons to be welded up. It is made of 5053 aluminum and welding with 5356 filler. It gets a 40 hp. mercury. Will look kind of like a www.craigcat.com boat with 3 wide seating when it is done. The top is still loose as there is stuff going on inside still to come. This is my first major aluminum project other than some small tanks and tabs and such. It did not go with out problems as I learned how plasma cutting leaves an oxidated edge and i made it hard on myself by getting it all tacked up from the inside and not being able to adequatly clean after I realized I needed to dress all the edges that were done on the HD plasma table. The 2nd. one should go much better and only take 1/3 of the time.
Using a Miller Dynasty 300DX TigRunner
