I need your ideas
  • I need your ideas
    Here is the puzzle: I have 10 frames 17'6" L 5'6" H 5'6" W and they weigh 3500lbs that I need to lift 13' and weld to embed plates in the ceiling. Placing them within 1/4" of the grid lines as well account for plumb. It's on the second floor and I cant get a fork lift to the site.
    How would you lift them?
    TJ
    TJ______________________________________
    lifting
    use anchor bolts at the ceiling then use pulleys to lift each corner tie frames up to ceiling "TACK OR WELD" u have it
      Assuming you have a hard floor you might be able to use a manual lift. We used to rent them to put up large signs. Looks like a cross between a plallet jack and a forklift. A hand crank raises the boom. I've seen riggers use them on several jobs moving heavy equip up to mezzanines. You would probably need 2 one on each end to handle the load and I'd still tie in to the ceiling pulleys to help steady it. A small sissors lift might also work.
      ****, Now that I think about it if I had to do it I'd probably talk to the guy that does the rigging for work medical equipment that I help install part time. They've got all the needed toys and let them worry about how to get it where you want it. Pass the costs along to the customer if you haven't already given the cust. a quote. They also carry the insurance if sh*t goes really wrong.
        Lift jacks and cribbing. You can meet all our tolerances easily that way.
          Hello, The equipment DSW is referring to is a Genie Lift. I have two of the 12 ft. models that I use to set beams and trusses with. I can flip the forks over and get 13.5 ft from them. They make several sizes with diff. load ratings, and as said above can be rented at rental yards. Good Luck.
            We have a couple Genie lifts at the plant, they have really saved us a few times when we couldn't get a forklift in
              Genie Lift's don't have the capacity, even the contractor model has a load limit of 650#. he'd need 5, six to to be safe.
                Keep it simple stupid.
                Do not preassemble the frames. Assemble the frames in place. Install one piece at a time off of scaffolding! If you already welded them together, you may have to cut them apart. Always have a plan! Remember the "6 P's".
                Proper Planing Prevents Piss Poor Production!
                  Is each frame 3500 lbs or the total of ten frames equal 3500 lbs?
                  Nick
                  Miller 252 Mig
                  Miller Cricket XL
                  Millermatic 150 Mig
                  Miller Syncrowave 200 Tig
                  2-O/A outfits
                  Jet Lathe and Mill
                  Jet 7x12 horz/vert band saw
                  DeWalt Multi Cutter metal saw
                  Century 50 Amp Plasma Cutter
                  Propane Forge
                  60" X 60" router/plasma table
                    how to lift
                    bent knees straight back and 2 secretaries from the front office TEE HEE
                      http://www.drywallhoists.com/index/Drywall_Panel_Lift.ASP
                      all joking aside now...
                      try this site and see what you think
                      http://www.drywallhoists.com/index/D...Panel_Lift.ASP
                        yeah TJ, get 24 drywall hoists.
