Drop Deck Trailer
  • Drop Deck Trailer
    Thought you folks might like to see a trailer I designed and built to load motorcycles and other heavy items from a flat position to a raised over the road position.
    http://public.fotki.com/Rbertalotto/...king_projects/
    A simple hand winch and cables operate the whole mechanism. A set of 1/2" locking pins hold the whole trailer together while moving over the road. This trailer went to California and back........
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Very nice, how is the pivot point made in the back ? I would be concerned about too much wobble where the bed of the trailer fits between the frame or isn't this an issue ? I'm looking to build a motorcycle trailer for my bike but I think Im going build it low and just tailgate it on. Eventually I want to build one to pull behind the bike as well.
    Ken
    What else is there besides welding and riding. Besides that
    Miller Thunderbolt XL 300/200 AC/DC
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
      trailer
      thats one fine piece of work for a trailer,well done
        When the drop part mates with the main frame, it all locks together with a series of pins with clevis pins. Solid as a rock when all locked together.
        The rear pivot point is hinged on 1" pivots. Once the trailer is in the travel position, the pivot point handles no weight.
        The best part about it is the comments I get when folks see it in use!
        RoyB
        Dartmouth, MA
        Millermatic 185 MIG
        Purox W200 O/A
        Grizzly 9957 Mill
        TP Blast Cabinet
          Drop Deck Trailer
          Great job
          should put a patten on that one
          Millermatic 212
          3035 Spool gun
          Miller Spectrum 375
            that is way cool. you gotta get us better pic's of how it works, so we can all steel your idea and make one for our selves. i would love one like that for my quads.
            thanks for the help
            feel free to shoot me an e-mail direct i have time to chat. james@newyorkmetalart.com
              AWESOME JOB...Good IDEA!!
              MillerMatic 211
                Novel idea my friend I would also like to see a pic from the rear of the trailer, if you have one. Very well thought out I'm impressed
                  Very impressive, thats one of the most unique trailers I've seen.
                  My sincere thanks , Pete.
                  Pureox OA
                  Westinghouse 300 amp AC stick
                  Miller Syncrowave 250
                  Hexacon 250 watt solder iron
                    check out his link to pics in the original post
                    Syncrowave 250DX
                      Here's a couple of rear shots.......
                      BTW, the best use of this trailer is moving machine tools that don't like to go up a ramp easily. I've moved milling machines and metal lathes with this trailer. Up to 2000 pounds...........real nice loading at ground level. The next one I build will have a simple plate of steel or aluminum for the deck. In this way it will be dead flat to load. This trailer has a deck with structure that is 4" high......
                      In the rear view pictures you'll see the spare tire. That is a counter weight to get the rear of the trailer down when it's empty. For a winch I used a side winder type so I can have total control of the lowering process. This type of winch is very easy to control with a load on it. And if you let the handle go it simply stops. You need to manually unwind it. I actually had an electric winch on it at first, but it was more bother than it was worth.
                      I'd take more pictures, but a neighbor of mine moving out to Californi bought it from me last summer and used it to move his bikes and outdoor furniture from Massachusetts to LA..........I got the parts to build another one this spring......
                      Thanks
                      RoyB
                      Dartmouth, MA
                      Millermatic 185 MIG
                      Purox W200 O/A
                      Grizzly 9957 Mill
                      TP Blast Cabinet
                        I like the trailer, good idea
                          do you have a pic or drawing of the underside,and the pivoting action ?
                          i could use one of those
                          my daddy always said i was IRONHEADED....
                          feel free to P/M me
                            I'll draw a plan and post in in a day or two...........
                            RoyB
                            Dartmouth, MA
                            Millermatic 185 MIG
                            Purox W200 O/A
                            Grizzly 9957 Mill
                            TP Blast Cabinet
                              cool................
                              thanks for the help
