Stainless Countertops
    Phax, what do you mean by "pickling" it? And as far as "welding the bottom seam and fusing the top", I thought the sheets were butted up (edge of each sheet) together? so there wouldn't be much of a seam, eh???
    thanks muchos,
    bert
    I'm not late...
    I'm just on Hawaiian Time
      SS machine
      Best machine for onsite or mobile on SS IMHO is the Passport. It is light, runs on 110 or 220 AND has a setting especially for SS. I have done numerous onsite repair jobs in restaurants and it works great. Also, tri-mix gas is recommended for SS.
        the passport would be grate is ya have the $$ and or the work load to support it. good excuse to give the wife to get a new toy. i was supposed to do some SS restaurant work for the wifes ex-boss,( that put the seal on getting the TA-185, it was building carts at home) but she quit the job and i lost my connect.
        the passport + allows for aluminum (not just a spool gun but a different arc as well) well worth the little extra $ to go +
        pickling is a chemical wash.
        thanks for the help
          mikeswelding,
          thanks, do you know the best tr-mix to use? I talked to a guy that had a friend using a "special" tr-mix for doing aluminum sched 40 truck racks. Racks were beautuful, and he said he didn't know what it was, but it was a "special" tri-mix his friend used other than 100% argon or 10% helium/90% argon that most people use for aluminum.
          Fun, do you know what the pickling recipe is?
          thanks guys,
          bert
          I'm not late...
            little dill weed, some vinegar, and..........wait you meant for SS.
            naaa sorry been years sense i worked with plaiting metals, and the old noodle is full of too much useless info to dig out the good stuff.
            thanks for the help
            • #21
              A friend of mine uses "Stargon" from Praxair for the stainless that he uses in his sculptures. He dosen't know what the mix is though. You could google it though.
              • #22
                Pickling
                James,
                LOL, sounds like Cliff on Cheers....my mind is like that too! Whish I was like
                Dumbledor in Harry Potte and put/save my useless thoughts in the pensive
                I'm not late...
                • #23
                  tenfingers
                  thanks for the tip, I'll look it up later
                  I'm not late...
                  • #24
                    I have a little Lincoln SP100 w/.023 SS and tri mix that works quite well for the little SS I do.
                    • #25
                      The Stargon SS Shielding Gas, a mixture of argon, carbon dioxide, and nitrogen, is designed for joining a variety of stainless steels under the most ...
                      findarticles.com/p/articles/mi_hb4400/is_200306/ai_n15309992 - 29k
                      • #26
                        thanks Bob
                        I'm not late...
                        • #27
                          Almost every place has 240V or 208V
                          I have a secret weapon... I made a welder plug with 2 25' 12ga extension cords going into it. Both neutrals are tied to the center leg, and each hot is tied to the outter legs. The other ends of the cords have standard 120V male plugs. Plug it in one outlet and plug it into another outlet on a different circuit. If it's a residential or commercial 120/240 1 phase service, 50% of the time, there will be 240V across the two hots. If not, try another plug on another circuit.
                          If it's commercial 120/208 3 phase, 67% of the time, you will get 208V. If not, try another plug.
                          You will get enough power to run a good size welder or plasma cutter.
                          • #28
                            How safe is the secret weapon? I guess it depends what exactly you plug into and that the equipment is auto line sensing...
                            John
                            Thunderbolt AC/DC
                            MM 175
                            Maxstar 150 STL
                            Blue Star 185 DX
                            Spectrum 375
                            • #29
                              Bodybagger,
                              thanks for your tip, I REALLY appreciate it, but you just scared the SH*T OUT OF ME
                              I think I'll stick to the "regular" pigtails
                              bert
                              I'm not late...
                              • #30
                                fuse tig the seams. Done tons of stainless work and all I have ever done is fuse it. My old shop had a 12ft wide hydrolic brake and we bent them up in house to avoid having to use seam sealer. You do not want to use that in this application. It will collect food and crap and defeet the purpose of having S.S. countertops.
                                Get the stuff bent up then do the welding and finishing yourself.
