I was just wondering wat High tech things y`all have welded on . Most high tech thing I ever welded on was a Late model roll cage(frame wat ever y`all want to call it)
I'd have to think hard about the most high tech one, but one of the more memorable was when I built up and reground the motor shaft of a Ford Model A horn motor.
$350,000.oo+ CDN 2007 Kenworth C-550B Tandem Steer, Tri Drive cab & chassis mounting new Manitec 3577 (35 ton 77 feet tip height) truck mounted picker.
Next is 2 of 2007 Kenworth C550B Double set-back Tandem Steer, Tandem drive cab & chassis that we are making into gin-pole trucks. Close to the same price as the picker.
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
I'd have to say this stuff. This company I work at. We make stuff for chemical/petro-chemical processing, water treatment, mining industries, water well industry, etc...... I weld on carbon steel, SS, hastaloy, titanium, etc. I work on everything from wire thats 0.010" dia. to plate several inches thick.
most of my work is in pharma / Biotech so most of it is high value/spec. working on something slightly different now, Largest producing dairy in Europe (rumoured to be biggest in the world but not sure) everything on here from 1/2" tube to 12" Shd 40 all stainless and there's some reasonable sized gear in here too.
Should be producing 10.5 million litres in a week when all online. they even make the bottles here.
hey anti gma i worked at weatherford too but in red deer ab. but we fixed mills and other down hole tools, also built most of their rental equipment. swivels, accumulates, and cat walks.
like these but way way nicer and they were trailer units.
[QUOTE=arc;10211]hey anti gma i worked at weatherford too but in red deer ab. but we fixed mills and other down hole tools, also built most of their rental equipment. swivels, accumulates, and cat walks.
also have been working for a frac company called sanjel and we have been replacing and repairing all of their equipment.
check them out some of the units are worth around a million and more.
sanjel.com/press/videos.cfm
Ya, we make well screen for the most part. Thats about the extent of our involvment in the water well area. But we make a heck of alot of it and some prety good size ones too (30" in a single roll). We make an awful lot of stuff for the petro chemical area. UOP LLC is one of our largest customers along with DOW Chemical corp. Where curently doing a styrene filter element for DOW's new 500,000 ton/anual styrene facility in suadi araibia if I recall corectly. Did you like wetherford or not? I don't, I think theres WAY to much politics in that company. Other than that it's ok I guess. But I sure have learned alot about fabricating in general where I'm at now. The second link you posted didn't work, the first one did though. What was that thing? I understood it's use but I couldn't figure out what that thing was or how it worked.
Reason: broken link
there were way to may politics there, that is why i left there. that skid unit is for service rigs that need to drill or mill out a hole. they also use them for fishing some times.
how it works: the yellow bowen head is lifted off them lifted up in to the derik . then they use drill collers just like a drilling rig.
try sanjel.com then click on the video at the bottom left.
trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
way to many other tools to list
Ya, I'll be leaving shortly for the same reason too (umong other things). I found the link shortly after righting my last respons, turns out the smilly you inserted after the link transfered as well. That's some pretty cool stuff. So if I understand corectly they diagnose and fix problematic wells? Those were some pretty wicked rigs they have. I understand that skid now, it looked kinda akward at first
