Broken Bandsaw blade
  • Broken Bandsaw blade
    Guy's, My bandsaw blade broke last night. It is a new blade on an old saw. I bought this saw off e-bay a while back. It's an old do-all. I think one of the wheels is out of alignment. Anyways, I am thinking about trying to tig this blade back together. Any suggestions, Thanks, Adam
    Webb's Welding and Repair LLC
    MM210 w/a 3035 spoolgun
    Spectrum 625
    Trialbazer 302 w/HF
    http://webbsweldingandrepair.com/home
    Try silver solder or Tig weld it with silica bronze rod. I've heard of people mig welding blades back together, just to get by, but I've never tried it...
      As another approach, make sure you have near perfect fit up, make sure the ends are held tight together, and just fuse it with the TIG torch.
      That's basically what a blade welding machine does anyway.
      Worth a try.
        I have tried both MiG and Tig to weld them together and MiG seems to hold up better for me.
          Just tig welded one a week or so ago. Works great.
          The fit-up is very important, straight and flat. After you carefully grind it, lightly anneal it with your torch. Just get it cherry red.
          Good Luck!
            Thanks for the input, I'm going to try it tonight, Adam
            Spectrum 625
            Trialbazer 302 w/HF
              bandsaw blade
              I have done both mig and tig on broken blades and both seem to hold up fairly well, but as mentioned earlier in this thread make sure you anneal the blade to soften it back up. Dave
                Bandsaw Blades...
                Hey guys,
                Just thought I'd pass on some info that may help those of you who use a bandsaw regularly. I have both vertical & horizontal bandsaws and go thru blades often. I use 1/2"X.025 in 14tpi & 18tpi. I purchased one of the Harbor Freight bandsaw blade welders very reasonably on a sale flyer and it works perfectly. I buy blade material in bulk 250' rolls from an E-Bay company, SDI Hardware. The 14tpi is $55/roll and 18tpi is $66/roll..that's 20cents/ft for 14tpi & 25cents/ft for 18tpi....very inexpensive compared to going to a hardware or Lowes/Home Depot. The blade welder I got on sale for $129 and it has paid for itself many times over. Hope that may help anyone going thru blades often and wants to save quite a bit. BTW, I also silver-soldered broken blades in a jig I made and also TIG & MIG welded them before the blade welder purchase. Annealing is the most important part of getting the weld to hold.....Denny
                * Complete welding, machine, & fab shop *
                * Mobile unit *
                * Finally retired *
                ____________________________________________
                * A man's word is his honor..... without honor, there is nothing. *
                * Words are like bullets..... once they leave your muzzle, you cannot get them back. *
                * I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
                * Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
