Latest Project.
    Originally posted by gnewby View Post
    Trailer looks good, was also wondering about how you made your hinges and your latches for your tailgate? Also your cherry picker did you make it also if so could we see another photo or two of it?
    The hinges are 3/4 bar drilled through the center with a 3/8 bolt through the center. 3 sections for each hinge, 2 welded to the main gate, center welded to the second gate. 8 hinges total. Had to grind a small clearance for the hinge not to rub on each gate. Works great, my Valkyrie interstate weighs 940 lbs, and my 200 lbs on it, the gate does not even flex when loading it.
    Miller Econo Twin HF AC/DC / Gas Tungsten Arc.
